Painting Intercooler πŸ€”
Issafit
U.S. Army Veteran
Reno, NV, USA
So i have the black whooshmotorsports intercooler. However i wasnt silver, so i was thinking either painting it silver, stripping it then painting it or just trading someone. Not sure if just repainting it would mess with the functionality of it at all though.
Thoughts?
Thoughts?
Powder coat it*
Northern California
I would never paint an intercooler, certainly not powder coat (way too thick). Any paint you put on creates a layer of insulation between the metal and the air. That lowers the effectiveness of the intercooler fins. Best to have metal and air touching.
Some of the ceramic coatings claim to actually be (or to
promote) 'heat dissipating' (like CP-E's does), but I am not quite sure that I believe them. [wink]
The margins are so small it would never be noticed. Or you could get it ceramic coated also* both are great ways to protect your investment and personalize it. It's your CAC ....your choice.
Had to sand the paint off my motorcycle OEM radiator spigots. After eleven years and 65k coolant started to randomly go missing. The paint was starting to break down. Everybody thinks the little bit of black stuff in the coolant is from the OEM silicon/rubber formed hoses but it isn't. That radiator has five connections.
@vivx - Seems the nutshell of that video would be, larger difference with passive cooling (note: keep out of sunlight), small negative impact to active cooling. One potential impact to cover is dirt/dust adhesion versus corrosion protection. Aluminum or "aluminium" as the Brits say, turns to a white powder as it corrodes. My guess, initially the paint would be a better surface for dirt/dust adhesion, but over the long term the differences would become less significant. (avoid washing a hot radiator BTW)
CT
yeah as a not-so-proud rustbelt inhabitant Im glad my whoosh v3 is coated!
