FS Complete Part-Out of Track Prepared 2015 - REVISED/UPDATED WITH MORE SHIPPING OPTIONS
Trader history for cidsamuth (1)
Northern Virginia
Okay, the frenzy has slowed and allowed me to take inventory of remaining items and to begin pulling parts that are not spoken for. Updating this to clearly show what's remaining for sale, and I can ship more items that I previously thought would be pickup only. I will begin posting pictures of these items as I pull them.
Reminder that I'm located in Northern VA. No items will be held without at least a good faith deposit.
  • Konig “Lockout” wheels, 17x8, gloss black with 225/40/17 Hoosier A7 tires. The wheels were used for a season and have normal wear and tear – mostly just dirty. No curb rash and includes all center caps. Includes metal hubcentric rings for the FiST. The tires were just purchased as scrubs and advertised as having 75% remaining life. I ran them for a little bit, and they still have close to the 75% lift, though have lots of rubber on them (picked up from the track). One tire has a very slow leak, but it was inconsequential to me, since I adjusted pressure before each track session anyway. $500 for all plus fees. No shipping.
  • Transmission. This is a BRAND NEW transmission from Ford. Has less than 100 miles on it with no issues. I had a Wavetrac LSD put in it (I had used the Wavetrac for two seasons in a different transmission), and I had the 4.3 final drive upgrade done with brand new parts. The install of the LSD and 4.3 into the transmission was done by PTuning in Manassas, VA. Anyone who has had the 4.3 done knows how much extra pull it gives you, and it is a real PITA and expensive to get installed. Note, you’ll need a tune change for this – not only for the gear ratio, but the torque tables will need adjusted by the tuner because of the increased torque, especially if you are big turbo. Price is FIRM. $3,000 plus shipping.
  • TB performance Rear Crash Bar, Red. Will have minor scuffs on it, but overall in good shape, and it will include the tow strap. $200 plus shipping and fees.
  • Rear Diffuser. This is made out of aluminum and bolts up with brackets. Includes Professional Awesome support rods. $150 plus shipping and fees.
  • Front Big Brake Kit. This is a custom-made kit by TCE that ran $3k new. It is truly made for racing, and it includes custom brackets and rotor hats made by TCE. It uses true Wilwood Racing 6-piston calipers, Model 120-13267 and 120-13268 (not retail off-the-shelf stuff), radial mount design, with Thermlock pistons. The kit uses large 13.06 x 1.25” vented rotors (I use the Wilwood Spec 37 rotors, #160-8165 and 160-8166, but there are cheaper variants). Even without ABS, I routinely out-brake much more expensive cars with these, and the pads still lasted 8+ track days. I used to burn up the standard off-the-shelf Wilwood BBK marketed for this car . . . but this custom kit handles anything you can throw at it and, frankly, is overbuilt for the FiST platform. Sale will include the calipers, brackets, rotor hats, steel brake lines and spacers for behind the pads (used as the pads wear to preclude the pistons from extending unnecessarily). I can include the used rotors if you want, but they are older and will only increase your shipping costs. I will also include nearly brand-new DTC-60 pads (about 50 street miles, plus only 6 track laps). Note: You will need 17” or larger rims for this setup. I also used wheel spacers also – exactly how much offset/spacers you need will depend on the exact wheel. For instance, I found some wheel designs had a great amount of spoke clearance and others needed large spacers. $1250 plus shipping and fees for the brake kit.
  • Steering Wheel with adapter. It says Omp, but it’s likely a knockoff and this is NOT a quick release setup. Works well, though. 325mm (faux) suede leather with yellow center stripe. $100 plus shipping and fees.
  • Wheel Spacers. I have two sets of H&R 20mm hubcentric wheel spacers with unused extended lugs (4 total spacers and 8 lugs). $100 plus shipping and fees. I also have one set (two spacers) of H&R that are 15mm, also with extended lugs. $70 plus fees and shipping. I also have some generic, universal spacers – two that are 10mm, two that are 5mm. Each pair is $10 plus shipping.
  • Misc Interior Pieces. I still have most of the interior pieces that came out of the car in varying condition. Regular seats, no Recaros. Will sell pieces cheap, so let me know what you need and make an offer. Shipping depends on what piece, of course.
  • Shell with cage. Once all the parts are off, I will sell the body with all glass, body panels and with cage. The cage is a custom-made full unit by Piper Motorsports in Leesburg VA, with optional door sill bars. The doors have been gutted and the windows bracketed in place (front windows get removed by hand before you hit the track). The cage, door setup, sunroof delete, and 6-point harness connection points ran me $7k. The body will include all bumpers, hood, doors, body panels, and the M2 fender flares which are a $750 cost new (the fenders are cut underneath for clearance). Front fenders will still have the vents, and the hood will still have the Verus vents with rain guard option. Will include miscellaneous items still in the car such as stock wiring harness, ECU, BCM, fuel pump, dash and stock gauges, rear axle, headlights and taillights, one key fob, etc. The idea will be that it will be a great starting point for anyone wanting to build their own race or rally car, alleviating the need for one of the most expensive parts – a good cage. Will come with title. Note, this started it’s track life as a “rebuilt title” car, so the title will reflect that. Everything is straight and true. Paint is in good shape for a track car, but you’ll want a paint correction or wrap if you’re looking to make it “pretty.” $4,000
  • There is a ton of other stuff on the car, obviously, so let me know if you need something you don’t see in this thread.
cidsamuth
Northern Virginia
Thread Starter #2
More pictures . . .
cidsamuth
Northern Virginia
More pics. Note, the picture of the motor on the stand and the front end without the bumper are from during the motor install in January 2023. All other pictures are new.
cidsamuth
Northern Virginia
I took a video today (5/12) of the engine running on cold startup. Figured it a good idea, since I’ll begin dismantling the car and it won’t be running going forward. Purrs like a kitten.
Unfortunately, the video is too large and it won’t post here. If anyone is interested in the motor, shoot me a PM, and I’ll get the video to you.
kevinatfms
Germantown
Ill take some credit for the build on the motor...LOL
also will vouch entirely for the car/parts. Mr Cidsamuth has pushed the platform beyond anything Ford could ever have imagined. Its been a pleasure to watch this thing go nuts at our local track(Summit Point).
100% seller recommended.
cidsamuth
Northern Virginia
Thank you, Sir. Yes, for anyone interested in the motor, know that it got the love and expertise of former Ford Mastertech Kevin with the install of the ARP head bolts and timing belt. Would explain why the motor was top notch this past year :)
Riverside,CA
FWIW - I parted out a car before and because it was so many parts like this part out is. I posted my zip code publicly and would tell buyers to check shipping rates. Some of them even bought their own shipping labels and emailed them over so I could print them. Saved me the hassle of checking rates and paying for labels.
cidsamuth
Northern Virginia
Bump to update what is left. Will be adding pictures of the items listed above as I remove them from the car and prepare for pickup/shipment out.
cidsamuth
Northern Virginia
First up …. pictures of the motor and transmission
cidsamuth
Northern Virginia
Here are the pictures specific to the front brake kit. As stated above, you will not get better for the car if you track it. The trade off being that you have to ensure wheel clearance.
cidsamuth
Northern Virginia
Wheels/tires, spacers
