Woods247 BrokeFiST Build
Woods247
Woods247
Thread Starter #1,921
Compare them to any wheelset I’ve had and they’re much heavier. The TH2s are a close second. 17x8 KE’s are as light as 17x7 Leggendas and lighter than 17x8 Grids by a little. If I only had one set it would be the KEs no question. Not sure how well they’d hold up to street use though.
I will find out in the late spring, when it is safe to put 200 tread wear 'endurance' type AD09s out on the roads again, here. [thumb]
WannabeST
Should I buy a carbon hood? 🤔
If you just want the carbon look, then go for it.
If you want weight savings you would be better off making your own or paying someone to make you one (ideally in dry carbon as its one of the lightest) . As mentioned above seibon is not the best. In many cases their items are heavier because they just put a single carbon layer over a bunch of fiberglass layers. I have visited their facility here in CA. I would not buy from them honestly.
Molds are treated poorly, have seen fitment issues first hand, and the facility in general seemed poorly managed.
WannabeST
Bummer there’s no real carbon option. I bet AJ Hartman could make one.
I've seen those parts on some local Mustangs on NASA and all the owners I spoke with were happy with fitment and quality. And they seem to make things with weight in mind as well. I'm sure they could whip something up for you
Woods247
Woods247
Thread Starter #1,929
I have a sunroof delete from him on my E46 and it fits perfectly, even inside where the mounting locations are. Next time I’m up at VIR I’ll mention it. I’m sure it’ll be $4k though lol
I could get you one made for about 50x that cost if you want F22 raptor stealth carbon fiber lol
I'd say it's worth it if you are running out of other weight-loss ideas. Swap was easy and the CF hood is much lighter. I don't have a way to measure the hood weights but it's about 10 lbs lighter per the Fiesta ST Weights Thread. I added a couple of washer for the rear to line up, but otherwise, the fitment is good. Rubber piece you see in front is due to the bumper cover bulge from the aftermarket IC install and was there before the hood swap.
Their CF hatch, on the other hand, doesn't fit was well. It's hard to tell in this picture, but the gap on the left side is about double the right side. But I guess making a hatch is more complicated than a hood.
Woods247
Woods247
Thread Starter #1,934
View attachment 65629 View attachment 65630
That's beautiful and very tempting! Thanks for sharing. i really appreciate it! A buddy is about to install a hatch on his. I look forward to seeing it in person.
Woods247
Woods247
Thread Starter #1,937
😂 that’s not a bad idea. Blue and purple flames all kook style.
Checkout what Dakota whipped up at 2J Racing this morning. Those guys are so awesome. Slammed with work but put it all aside and built me a delete so I can take the car to Road Atlanta tomorrow. I wish they had more support from the Fiesta community. You guys should see the Ti exhausts with carbon tips they make for the Corollas. It’s absolute art!
Woods247
Woods247
Thread Starter #1,938
I spent four days at Road Atlanta this week. Three with the Fiesta. The car started misfiring under WOT during the last session after I added 6gal of e30. The gas is likely ok since I ran 12gal of the same earlier without issue. Hoping a spark plug loosened up or maybe a coil is going bad from excessive heat. I’ll tear into it when I have time. No codes so hopefully it’s minor.
Woods247
Woods247
Thread Starter #1,939
Oooof. Just got an opportunity to buy a dream car I’ve been familiar with for nearly a decade. I don’t think this one can be passed up. Never say never I guess. There’s a local who’s wanted my Fiesta for several years. It might be time. By the way, the stutter was just old plugs and lots of track time last week. Easy fix per usual.
