LSD Questions
you felt the clunk of the chassis sitting on it
The washer fluid reservoir is tucked inbetween two solid points. One is the frame that supports the bumper on the driver side. Based on your description there's a chance there will be some deformation to the frame that supports the front-end. Doesn't take much. Your standard auto repair won't want to mess with anything that has damage on that frame rail. Some vehicles there's a short section of frame that bolts on/off but the example I've seen, there was still deformation to the permanent section that doesn't bolt on/off. A welder that works well outside the normal boundaries and restores vehicles, may entertain the idea of cutting off an undamaged section of frame from a junkyard donor and reattaching to your vehicle.
I have mine apart now, replacing the steering rack after an Amazon contractor package truck hit it last year this time (and ran) while parked on the street. Been mostly parked as the torque vectoring and torque steer compensation make it difficult to impossible to drive anymore aggressively than a Grandma. My damage is primarily steering and suspension geometry. Barely been driven since then.
Irvine, CA
Don't forget we have Torque vectoring baked into the the ABS which helps eliminate the inner wheel slip
The TVS does absolutely nothing for one wheel peel while cornering. It’s an ineffective nanny system that only pre overheats the brakes during spirited driving. The TVS in no way, shape, or form compares to the benefits felt from a mechanical LSD pulling the front of the car out of a corner or maintaining traction on slippery surfaces. Any beliefs to otherwise are the result of a marketing department.
foodtruck
BC, Canada
Darn, I remembered that bottle to be more out in the open than it actually is :cautious: But seems like the actual frame is much higher up (blue beam). What's the black curve-y bit, just the bumper plastic? The transmission looks like its on the same level as the bottle, however...
The slider pin boot looks like it had seen better days.
I had excess grease in them. Excess grease got squeezed out, leaving no air to replace the grease. As long as they remain like it is, that's an indication that it's still sealing. 👍 They're all looking "tight" like that.
Hillsboro, Oregon, USA
I thought I ran out of windshield fluid like 4 months ago. I don't really use it so I didn't bother replacing it. Well, i went to refill it yesterday and the fluid just poured out. Based on how quickly it flows out of the res I'm assuming it's cracked pretty good. I figured I'd try JB-ing it before ordering a new one or finding one in a yard. There are weirdly very few fiestas in the yards around here. I guess recycling is working.
Is it seriously this much work to service this reservoir? What a lame design. I don't wanna remove that liner, lol. I know I'm gonna break some of those plastic clips that have 150k on them.
