Boost Leak Problems
So, I've got a boost leak. At least, that's what Jason at Dizzy is telling me. I'm sitting at a max boost of 20PSI, and I've checked every boost connection on the vehicle without any luck, and I'm out of ideas. Jason told me that his tune should max out at around 26psi (+/- 1psi) I even purchased a new Symposer delete as the one I had was a bit finicky and I wanted to rule that out. I have a track day at the end of march and I don't feel like driving the Fiesta while it's maxing out at ~177HP is going to be good or fun. Anyone have any ideas what it might be? The car has 121k miles, could it be a turbo failing?
If I can't get this solved, should I just flip it back to the Cobb stage 2 tune? I think the Cobb Stage 2 tune maxes out at 21PSI so I might have a bit more performance while trying to figure out what in blazes is going wrong...
S
Pardon my ignorance but what’s the difference between a diverter valve and something like the turbo smart bov? I’m thinking of going hybrid turbo in the future and the cost difference between the diverter+ and the turbosmart 14psi is negligible. If they install in the same place would replacing the stock diverter with either possibly fix the problem?
Matter of preference but I would go for the turbosmart. Electrical or mechanical actuation doesn’t matter much, also a matter of preference. I prefer mechanical BOV/BPV. Keep in mind you need to make periodically service an aftermarket unit and that’s a huge pain on the turbo which is why many block off the turbo port and put a VTA blow off on the symposer port.
BPV is a common source of boost leak. I’m sure you have already gone through and checked all your hose clamps between the turbo and throttle body and inspected the intercooler for cracks so the BPV is a logical next place to look. Your turbo may be tired as well.
Diverter serves the same purpose as a BOV, and is how the factory boost pressure is handled on throttle close. A diverter recirculates the boost into the intake system whereas a BOV releases that into the atmosphere for that pssh pssh...
Now you mentioned turbosmart 14psi, and that would be in reference to the waste gate actuator. The waste gate controls boost pressure at the turbine by bypassing the turbine via a door. The actuator has spring pressure which relates to the minimum boost it will allow a turbo to produce. So a 14psi waste gate actuator will not allow you to make less than 14psi, factory is like 5psi...
XanRules
IF you have indeed THOROUGHLY checked every single vacuum connection, I believe I had the same issue when I got my tune and it was also the diverter valve. I would also agree on the GFB - I will always prefer a mechanical piece like that rather than electronic or digital but this is entirely personal preference. Check with Jason before you do this as he may have preferences on which one you should buy.
