Lemon's X47 track ST
lemonjs
Thread Starter #221
Stripped the engine down today to try and find out what happened.
Firstly did a compression check and had 180 across all cylinders which was a surprise, but when I looked into the bores it was clear that something had been banging around in there. The pistons and head had massive chunks taken out of them and there was vertical scoring along the bores. There was some small blank chunks of metal pressed into the head and bits kept falling out as we stripped the car down.
I pulled the turbo and split it and found that the turbine had broken apart. The turbine material is a match with the small black bits of metal, but what I can't understand is how exactly they got in there. I would have expected them to go straight out the exhaust but they have made their way into the combustion chamber.
Annoyingly when we pulled the cam covers off the cams look perfect, almost like new! It's a shame that this engine has survived so much only to be taken out by a Pumaspeed turbo :(
Picking up a replacement engine next week and will hopefully get it fitted over the weekend. I'll go back to stock turbo for now so it runs, but will be going S280 in the near future.
lemonjs
Thread Starter #222
Picked up a replacement engine last week - JTJB engine on 55k miles with an S280.
Was a big day yesterday - firstly went to Thruxton to sit my ARDS exam which I passed. It's the exam you need to sit in the UK to get your MSUK competition race license. This will allow me to compete in circuit racing, Time Attack, hill climbing or anything else I might want to do. It starts with a classroom theory test and then you go out with an examiner on track and they asses your driving to see if they think you'd be safe in a grid full of other cars.
Afterwards drove to the garage to get the engine fitted. Took about 12 hours to get the old engine out, do the timing belt and water pump and then get everything refitted. Haven't been for the maiden voyage yet, but should hopefully get it booked in with TRS at the end of the month to have it tuned for the S280.
The replacement engine was on its original belt but was at least in time. The engine came with a new FoMoCo timing bet kit so swapped it over while the engine was out.
Back together and running by midnight!
I probably would've done the water pump as well while it was all apart (unless you removed and inspected it and it was in perfect condition?).
lemonjs
Thread Starter #224
The photo is from before I did it - the water pump was done too!
lemonjs
Thread Starter #226
Yet to decide if I want to do Time Attack or club racing next year, but either way there's a few things I need to do (and a few things I want to do) to be ready.
First up was to install wire tow loops - the MSUK rule book says that 1 front and 1 rear is required, but 2 at each end is preferred. I wanted to preserve the fixed front tow hook so I have them coming out of the grille. I used an M10 12.9 bolt with a thick washer on top and bolted them into the crash bars with nylock nuts. While I had the bumper off, I also installed the MGC splitter brackets. Still need to pick up some plywood to make the splitter.
The last few big items to do before I can get a test scrutineering are:
- Fit an FIA approved seat
- 6 point FIA harness
- Plumbed in fire extinguisher
- Replace my existing battery cut off switch with one that's accessible from outside the car
- FIA rain light
And the things I don't need to do, but will:
- Refit oil cooler
- Drop the car 10-20mm - just need to make sure I'm still above the 40mm minimum clearance
Do those flop around at speed, or under cornering g forces, and knock against the body/grille?
lemonjs
Thread Starter #228
I haven’t driven it yet but I suspect they will. You can tie them back but they must be quickly detachable by a marshal, so need to think of a solution. Velcro straps were my first though.
lemonjs
Thread Starter #229
Few updates since the engine swap - firstly I took the car to TRS to have it mapped for the S280. It was one of the hottest days I've ever experienced in the UK at 34c (93f), I know this probably sounds weak compared to the US but the guys working on the car were dripping!
I asked for a few changes compared to the way the car was set up last time with the X47. Most importantly I wanted lower boost (to keep temperatures lower) and for it to come on more progressively so that it didn't light up both front tyres on corner exit and kill driveshafts. We had some issues with the dyno on the day and the clutch kept slipping which not expected. In the end they road tuned it and everything was fine so suspect it was the dyno itself. Took it to Surrey Rolling Road the following week and had no issues, and made 280hp which is right about where I wanted it to be.
Continuing the work for Time Attack next year, I installed an FIA approved seat and an FIA approved 6 point harness for HANS. I'll keep the old seat for when I go back to the Nurburgring as there's no way they'll allow it for TF.
I also installed a pull cable bracket from SW Motorsport for me to mount the fire extinguisher and cut off switches when I fit them:
lemonjs
Thread Starter #230
First track test since the engine swap at Snetterton. Headed up the night before and camped out in the paddock which was cool, had the whole place to ourselves! It was disgustingly hot on the day at 38c (100f) - I went my entire live never seeing north of 25c (77f) until the last 7/8 years and now we're pushing 40c (104f). Both me and the car really struggled in the heat. I had removed all of the plastic air guides from under the car to make room for the splitter but couldn't get it fitted in time. Had a lot of trouble with intake air temps and later in the day even had coolant temp issues. Called it a day at 14:00 as both me and the car were very cranky!
Good news was the car survived but have a lot of work to do to get it where I want it.
Not sure if you guys ever got the Ford Puma in the US but my friend has one. He paid £200 scrap for it and welded it up. Totally stock besides being stripped out and the thing is an absolute riot. It shares a platform with the MK5 Fiesta Zetec so has some good parts availability. The engine was co-designed with Yamaha and revs like a champ.
Those are the same tail
Those taillights look the same as the Mercury Cougar this side of the pond. Car never took off here.
We never got the Puma, old gen like pictured above, nor current gen CUV which is the 'silhouette' for the current Rally 1 car.
That first gen UK/Euro Puma is a totally different platform from the shortened Contour (Mondeo for you) platform our Mercury Cougar was based upon, although yes, it does share some of it's design cues.
lemonjs
Thread Starter #233
More Time Attack prep for next year - Aero! Fitted an MGC Modifications rear mounted wing and chassis mounted splitter. Had a friend cut out the splitter for me out of 12mm phenolic plywood and seal the cuts. A few weeks ago I fitted quick release bumper/fender catches which have already paid for themselves! Took 10 seconds to remove the bumper instead of fighting to get the 3 wing bolts out. No issues fitting either, and despite the wing not being chassis mounted it feels rock solid. It is just narrower than the width of the car, although I still think TF at the ring will be off the cards now.
Haven't fitted the air dam yet as I'm not sure if I want to go down that route or use some adhesive foam instead - not really a fan of how the air dams look even though it would be very effective. Booked Castle Combe for the 25th September so will get a chance to test it all out.
Still need to fit the plumbed in fire extinguisher, external cut off switch and hood pins, but that can all be done over the winter.
lemonjs
Thread Starter #235
That is one of the nicest wood composite splitters I've ever seen.
What is it that you don't like about it's aesthetics?
Agreed! Really happy with how it turned out. Glad I had a carpenter friend cut it instead of me.
I think the air dams look like someone screwed some garden edging onto the front of their car (which is exactly what I'll probably end up doing).
True, but in the rally world, even tarmac rallying, the surfaces they must blast down are nowhere near as smooth as on even the worst tracks, including any high curbing.
So they are forced to use those 'garden edging' front air dams as any actual splitter would last less than a stage.
