installing Colby Transmission soon. Any suggestions with what else to consider?
ronmcdon
ronmcdon
Thread Starter #22
They did dyno with a SAE dynojet. figures were pretty much what I expected. Sadly not a whole lot more can be done other than fueling.
btw added more a few more parts.
threw on another Anti Gravity lithoim battery.
Vic @ FSWERkS may have figured out why my previous litium battery kept dying on me.
wiill report more.
Oh also will throw on some ricey Verus canards and vents.
At this point pretty much done modding the car. I may look into installing my m2 fenders and finally throwing on the Braid 17x9 +35 (or +30 I forget) wheels Ive had sitting in my garage for past years, but that will be something for next year.
maybe should do a build thread because this thread really got off topic IMG_6832.jpeg IMG_6829.jpeg IMG_6830.jpeg
wiill report more. Will throw on some ricey Verus canards and vents.
Not even going to try the 30% injectors on a stock HPFP? I know the pumps are a pretty penny but uprated/port injection would definitely utilize that 280 more... Maybe used would be a viable option...
ronmcdon
ronmcdon
Thread Starter #24
would the injectors work with 91 octane?
what additional gains might and/or other benefits might come with that?
The larger turbo is flowing more air, you now need more fuel to match, 30% is the volume flowed so yes it would work with 91... Ethanol needs more fuel but burns cooler hence why uprated injectors/pump are recommended
ronmcdon
ronmcdon
Thread Starter #26
Ah good to know. searched some threads and could never quite get an answer on that. sent Adam at Tune Plus a message and see what he offers. He also sells said injectors. Hope dont have to upgrade hfpf
#27
If you go port injection the HPFP isn't an issue, but you you have the expense of additional injectors, if you go larger DI then you may run the risk of exceeding the pump... Definitely talk it over with the tuner, they should give you the pros/cons of each
ronmcdon
ronmcdon
Thread Starter #28
Ah definitely will check and waiting on what he has to say. either way pretty happy with what I got. will definitely see what gains the injectors get.
ronmcdon
ronmcdon
Thread Starter #30
Just got a reply from Tune Plus (mind you who is also selling the injectors, so you can see if he is a totally honest guy). Sadly some bad news.
Adam Brunson
Sent September 1st, 2025 8:47:59 AM GMT-7
It (the 30% injectors) works with any fuel but you aren't limited buy injectors on 91oct, so unless you plan on running ethanol mix there would be no benefit to upgrading injectors at this time.
So, unfortunately this seems like this is pretty much the full potential of the Fiesta St engine at 91 octane. Fuel seems to limit more than airflow. Hopefully I'm wrong and we see gains from stuff like the WOR exhaust manifold. maybe cams, but I'm not optimistic.
It's the same deal for one of my other cars, my '19 honda civic si, with 1.5l turbo (incidentally doing transmission work on that as well soon). Even with a larger drop in turbo it still bottlenecks around 260-280ish. Thankfully these cars are more about finesse and handling.
ronmcdon
Thread Starter #32
that silver e36 m3 was very clean. the design has aged exceptionally well though the decades.
#33
Adam Brunson
Yeah on premium fuel you’re knock limited. I gained 0 hp on 93 with both fuel pumps and injectors done.
ronmcdon
Thread Starter #34
Thats likely end of the line with power potential as far as this car goes on pump gas, and I think I'm okay with that. any other parts like ported manifold would probably net marginal gains if any.
Sad to say, but it feels like this car is more or less done as a project car. there's an odd sense of loss thinking about that.
#36
I worry about this feeling all the time. What’s the next project?
ronmcdon
Thread Starter #37
Personally, I find this to be the best part, putting down lap times with a “finished” project.
See you out on the track soon (y)
cant disagree with that!
what hdpe groups do you run with? been liking hooked on driving a lot, although usually they’re a bit further up north in laguna seca and my favorite track, sonoma
ronmcdon
Thread Starter #38
ive been modding my 14 evo x and 19 civic si (in retrospect have some regrets not splurging for a fk8 ctr, but have been intimidated by the overheating issues on track despite cooling mods).
my evo is probably 80% done if I don’t bother building the block. just need to throw on bolt on bigger 18k turbo and injectors I already have and maybe 6-7k in suspension parts.
my si, in mid Oct to sometime Nov, I am getting the trans built with straight cut gears, upgrading clutch, headstuds (known weaknesses), bolt on on 27won w2 turbo. just need to figure out the suspension. so also more than half-way done.
May get a g87 m2. I actually got an allocation early Sep with a build w/ individual purple paint. I am kinda conflicted because my heart speaks to a g80 m3 xdrive in individual wildberry or british racing green paint, but realistically its not a good a deal as the m2. never owned a bmw in my life and want an m car before they go electric.
#39
SlipAngle, ongrid, touge2track for the SoCal tracks.
I need to get up north this winter for some events. Sonoma looks like a blast to drive
ronmcdon
Thread Starter #40
sonoma’s the best. Laguna seca I kinda get the sense its more suited to higher powered cars with all the inclines and straights.
hoping to do thunderhill but its a real trek. heard streets of willow got re-done so hoping to go back.
on grid is a good deal!
