Installed the 4" SVT Design Fab intake. Pretty straightforward. This intake is massive. I makes the Injen intake I had look like spaghetti. I like the fact that all connections to the intake now are in front of the engine - nothing goes behind/over the engine.
Last pic is the "before" pic with the Injen intake.
drained my oil & tossed it right back in after driving 200 miles (used coffee filter to pull debris out), there was definitely glitter/shimmer all in that oil. pulled filter and cut the element out, almost no glitter in there. some black crud, carbon buildup getting out, whatever.
metal was not noticeable in the stream when draining but when i got to the bottom of the oil drain pan, it was. so, my motor will need to be rebuilt or replaced. i think i will start an “advice needed” thread or something. post the videos of each oil change i did there and go from there. i’m also getting excess pressure in my PCV catchcan which is making no sense atm. air getting forced out the dipstick hole when being taken out, maybe the intake manifold is plugged up. idk. torn on what to do with this car at this point. it’s silver and gold glimmer in the oil too i may add. this car has served me well for the 42k miles i have owned it and i don’t want to stop or switch to another fiesta, especially since this one is paid off.
drained my oil & tossed it right back in after driving 200 miles (used coffee filter to pull debris out), there was definitely glitter/shimmer all in that oil....
With my Fiesta, I try to look at challenges like this as opportunities.
It's paid off! Thats awesome.
Some folks would say to get rid of it and get another car. There's a cost involved with doing that.
For the same cost, consider an engine rebuild, forged internals. depending on how much of.the work you are able to do yourself, the cost may be comparable. I've seen complete rebuilds (Mountune, Engineered Motorsport) but there are also folks who sell forged internals kits (Southtown Garage, Mountune, etc.). You get a (basically) new engine, one more durable than stock, capable of even more hp.
While 10k might seem expensive, you are basically getting g a new car engine-wise, and one that's an upgrade from your current ride. And if you do the work yourself to rebuild the engine the cost is less than half of that.
Good luck! I know that's a bad feeling in the pit of your stomach when you see that glitter. I've been there!
it’s tough since i don’t make a large amount of money to warrant this & my car is at 181k miles… i was thinking of either finding a part out car on copart and taking its motor or just finding a used 1.6 online and tossing it in this car on a budget. i have a clutch i can toss in, and my trans whines but i can’t afford to replace it, so i think i was just gonna run it. it would be awesome to put a built motor into this car, but i bought it for 10k at 139k miles and i don’t want to put an equivalent amount into a built motor, especially when the car needs ANOTHER turbo, other crap like a windshield, hood, exhaust (ideally), clutch pedal assy, etc 😅
Copart is a solid idea. Guy got a good running car for like $4k recently, just had a sensor problem.
Any fusion or escape 1.6t is the same base motor, so probably can get a much better price looking for those vs one labeled 'ST'.
All that said, they are too good to get rid of over such things. I still cant think of a daily I would like to have more...
Neomax coilovers + rear shocks/springs are done! Took me all afternoon, mostly fiddling to get the rear spring preload right and rear ride height. The rear divorced shocks/springs are a PITA compared to the front coilovers. Lowered things a bit (on purpose), still need to drop the front another inch.
Test rides so far I'm very happy - seems to be smoother than stock (amazing but true -with everything I've done to this car I hadn't touched the suspension).
I may dial in a bit more firmness.
Also enjoying a bit of a different sounds scape with the 4" SVT intake. Turbo sounds are a little easier to hear - that's a sound I don't mind hearing!±
Officially totaled as of this morning.
Now the wait for the payoff. Still deciding what to replace it with.
up to you on what you want to replace it with, i would highly recommend a fiesta with recaros if you can swing it. unfortunately my car is eating itself alive so i wouldn't dare offer it
I've definitely considered another FiST, but I'd have to go at least 2-500 miles out to get one comparable. Closest 2 I found were in Lafayette, LA & Kansas City, MO areas, if I look for 2016+ and under 100k miles, not black or modified.
there's a 2018 with 61k miles, magnetic metallic, base seats, but $10,500 on fb here in Gilbert AZ. https://www.facebook.com/share/1DPdsLgxMH/
I've seen this and his other, I'm curious how long it can last with heat cycling and vibration since it looks like it was done with an FDM printer.
View attachment IMG_1620.jpeg Got hit by a Dakota at a stop sign while turning left, it was my turn and he just decided not to stop and continue driving into my car without hitting the brakes. Thank god for dash cams. Insurance told me it might be a total loss, but the adjuster suggested a good shop with lower labor rates to be able to save it. We’ll see. They will be picking it up tomorrow.
XanRules
This was technically a couple of days ago, but I had a nasty chip/scratches/etc in the windshield and got a new one put on. While I was there I had them put on the auto-dimming compass mirror from the Fiesta Titanium, which cost me like $16 at a junkyard with the wiring harness. Just need to splice the wires in.
Just got back from a 2 week work trip and remembered I hadn't updated. I'm set to get some more dyno time so I can get live tuning from Westley.
But the Mustang Dyno I went to put down peak 314 whp in about 25 degree warmer weather than my logging. Which aligns with the 355-370 whp of the Dyno Jet VDyno I've got for my logs.
Thinking about making my own ethanol gauge setup because I'd rather get the actual content now instead of just calculating it on "ideal" content ratings.
I've also got NIB Denso O2 Sensors that I never got around to installing. PM if you might want them
Denso 2344962 (234-4962)
Denso 2345113 (234-5113)
Might also have a Fumoto [F106N] & length adapter [ADP106]. Waiting to see if they'll exchange for the same for the Legacy. Because, of course it takes a different model [F108N]
Wanted to start a thread where everyone can share what they did to their Fiesta ST on a daily basis. You can share whatever information you want as long as it's relevant to the Fiesta ST.[lovest]
i finally got around to installing some new high flow intake pipes on my fiesta st today and the difference in the turbo spool sound is honestly incredible for such a simple swap it really wakes up the little 1.6 liter engine and makes the daily commute feel a lot more spirited especially when you are hitting those tight on ramps it is such a fun platform to work on because even these small weekend projects make a noticeable impact on how the car handles and sounds when you are pushing it
it is always great to see what everyone else is doing to their rigs because there is so much inspiration in the community right now for these hot hatches i actually went through a similar struggle trying to keep the paint looking fresh while parking it outside between these upgrades and a buddy of mine had the same issue while he was looking at a good mini cover selection before he finally found a breathable material that kept his finish perfect without scratching it
