Athena Autocross - Build - Ongoing
Not going to go over anything too crazy here at the start. I've had the FiST since 2021 and was practically stock when I got it. Current parts list is below in no particular order.
Engine, Turbo & Cooling:
  • Turbo Technics S280 w/ Turbosmart 14 PSI WG
  • Modified Stock Intake with RAMAIR High flow filter
  • Shaman Equipment Intercooler (Silicone Intakes)
  • TurboSX BOV
  • NGK Ruthenium HX 0.025 Gap
  • Mountune Triple Core w/ 180F Thermostat
  • Dizzy MAP Adapter w/ AEM 3.5 BAR sensor
  • Bosch TMAP 4 Bar
  • Turbo Technics hot side & Whoosh S bend
  • AWR 88A RMM, PMM, TMM
Exhaust:
  • Cobb 3" Downpipe/cat
  • Injen 3" Exhaust (Racing tip option)
Transmission:
  • Mfactory Differential
  • Whoosh Stage 3 Clutch (Spongebob)
Wheels and tires:
  • Team Dynamics Pro 1.2 15x8
  • Falken RT660 225/45r15
Fueling: (Most of this is new)
  • PHUL LSFP
  • Nostrum HPFP
  • Nostrum 60% Injectors
  • Nostrum FRS
Brakes:
  • Stock Rotors with Ford S pads
  • RBF 600 Fluid
Suspension:
  • Stock (Original) suspension with 80k miles
  • Whiteline Rear Sway bar
Right now I'm tuned with Westley Kimble who is handling revisions on an older tune base updated for the new Nostrum parts.
The car does see events with the SCCA and I'll be getting out to do some hillclimb and track days once the car is back up with the new fueling. I've done quite a few events and the car pushes strong getting me wins or podiums in STH, XA and XB as I've moved around.
I am on my second engine, first engine failed on the Nostrum HPFP destroying my intake cam, Nostrum did warranty that part which was wonderful and have been pleasant to work with through everything. New engine is from a 2016 Escape.
9.22.24 ER size - 900.jpg weeee - 900.jpg May 4th ER 2 - 900.jpg May 4th ER - 900.jpg
I do most of the work on my car myself. I've have multiple shops in the past work on the car and have caused problems in different spots with breaking things or just not completing them correctly, so outside of very intensive things like engine swaps or working on the transmission like the Diff I'll install them myself. HPFP, Injectors, Exhaust, Cat, S280, Intercooler and creating the bracket for that have been my own work. I've had to get under the car at events to fix things I've broken or lost to keep going before, only down side is I'm a parking lot warrior and don't have a garage.
I've recently moved, but my bench looks like a disaster every now and again as I work on the car.
I'll also work on nonsensical projects just for fun, Getting this gauge setup was neat but unfortunately does not provide enough detail for boost readings or other sensors so I've since removed it. But I have kept the suede like cloth on the covers.
And from time to time I've worked on designing my own parts. The most recent one has been designing a 3 in intake that is placed in the center of the cowls high pressure zone right above the HPFP which in theory should be one of the best locations as it's not restrictive like the 2J and still shortens the intake piping. Still testing this.
I also do videos for autocross that I'll update here.
https://www.youtube.com/@AthenaAutocross/videos
Most recent event was a few months ago where I finished 3rd in XB class and 17th out of 93 overall. (With a major boost leak unfortunately) - I also finished 3rd in my first season out of 150+ drivers who competed.
View: https://www.youtube.com/watch?v=KbjaQWSBzFk
View: https://www.youtube.com/watch?v=SQbBwqN5zX8
That should just about cover everything right now and I'll be update installs, events and questions once in a while.
Man, I miss auto-x. Used to do the [non-SCCA] A&MSCC runs when I was in college. Pretty sure they converted the old Riverside airfield into a sub-campus.
Guessing you're not around Houston, last I'd checked there wasn't much around here anymore. Since the Baytown dragstrip closed those auto-x events went away & the HPD academy doesn't seem to host anymore either.
AthenaAutocross
I'm actually no longer in Texas, I'm out of Washington now. I was racing in the DFW area with most events at LoneStar horse track. I'll be doing the SCCA group here and in the area and making my way out to Pacific Motorsports and Pacific Raceways Next year.
AthenaAutocross
Any rub marks on the inside of those arches?
None actually. No marks inside, no rub and no sidewall marks. These tires have had 8 events and about 12k miles on them from daily use and are over a year and a half old now.
Tomorrow is the last day I'll be on these, I just took these pictures. On the fence still between another set of RT660s or going with RE71RS for the start of the year. Downside of the 71s is they could raise the ride height a half inch. I'll be switching to my seasonal tires/wheels which are Nitto Neo gens, cheap and work well enough in the weather I'm expecting here.
Gotcha, saw the TX plates & assumed.
Can you give more details on the cowl intake? Im starting to think about developing one for my 2014 grm challenge car. I have my own ideas, but id love to see someone else's.
AthenaAutocross
The idea is like this, Under the inlet side of the cowling(the piece that is closed) you cut a section out for a intake to fit, in this case the 3" pipe, 5x9 filter I built. Then you run the sensors and extend the hoses needed. Instead of stuffing it in the corner like the 2J which doesn't get air, this sits in the highest pressure zone already open with the filter facing towards it.
This should allow the bay to stay pressurized so it doesn't mess with the radiator or FMIC. I'm still fiddling with the idea because I want to come up with something for rainy season. Which might just be slightly raising the box the filter sits in and then covering this section in green with a magnet cover to reduce any chance of water getting in.
