- Member ID
- #1972
- Messages
- 431
- Likes
- 73
So after a lot of research I finally pull the trigger and bought some Godspeed MONO SS coilovers for my ST. I gotta say first impressions was defiantly a 10/10. There boxed extremely well and assembled 100%. Here's the info on them copied from there site
Spring rates: Front: 5 kg/mm / Rear: 3 kg/mm
16 precise levels of damper adjustment
Koyo Japan 6204z bearing
Polyurethane bushing (if applicable)
Monotube shock design
Anodized shock body
Lightweight aluminum shock body and T7075 forged aluminum / carbon steel brackets
52mm carbon steel shock body with a performance internal piston
Independent ride height and spring preload adjustments
Race shock oil with a high viscosity index
1 Year Warranty from Date of Purchase
SpringFront Rear
Rate (kg/mm)53
Length (mm)200180
I.D. (mm)62 62
Camber Plate NoNo
Now for ride quality, it's pretty impressive. Equal ride quality to any coilovers I've owed IMO, Megan racing, JIC magic, tien ect... now the biggest question is the life span. We'll soon to find out. Going to be doing a few track days this year, also my fist is my daily so let's see how it does as a everyday damper. If anybody on this forum is looking for a great quality with a affordable price, I would defiantly recommend these.
Anodized shock body
SpringFront Rear
Rate (kg/mm)53
Length (mm)200180
I.D. (mm)62 62
Camber Plate NoNo
