Buyer’s Guide for Fiesta ST
Swhornor
I’ve been doing a little bit of research on the Fiesta ST. Seems like a really fun little car, and has a lot of utility too. In looking for a buyers guide, nothing seems to come up that is more recent than a couple years ago. If you were in the market for a Fiesta ST, what would you make sure you had? What would you avoid aside from usual rough examples and crash cars? Is the DCT a no go, or are they just rough but still reliable?
Thanks!
Capri to ST
Here's a thread I started a few years ago that describes changes and improvements to the car through the years.
https://www.fiestastforum.com/threa...-improvements-to-fist-through-the-years.9186/
They were fairly similar for the whole model run.I would generally recommend looking for one that's a 2016 or newer. First, they have the newer Sync 3 screen system. Secondly, they avoid a recall on some of the earlier cars from the '14 and '15 model years for an overheating issue. Apparently the head was changed and updated on the cars made from 2016 on. The ride was also softened up a bit starting with early in the '16 model year, which some people including me found helpful.
All model years had an option to have Recaro seats.They are very much a matter of personal preference. I have them and love them but they just don't work for some people.Cars from I believe 2018 on have a backup camera, which I would have liked, but that wasn't a huge deal to me.The DCT was not available on the Fiesta ST, only on the regular Fiestas, and apparently it did have a lot of problems. Finally, sometimes if you can find a car that wasn't extensively modified it might have a better shot at not having had the hell driven out of it.
SteveS
There aren't any buyers guides more recent than a few years ago because they haven't been sold here since 2019.
The DCT isn't available in the ST. It only came with the 6 speed manual.
There were hardly any options available, so most came equipped similarly.
The early cars had overheating problems due to the cooling system tank, so there was a recall. That covered 2014-15.
The suspension got a recalibration in roughly 2016, which is also when the Sync system got its upgrade.
Backup cameras came in, I believe, 2018.
Cars that came with summer only tires got different brake pads, identifiable by the red brake calipers. But you can install whatever pads you want, and many used cars will already have aftermarket pads.
The Recaro package is desirable unless you're one of the people who doesn't fit in the narrower Recaros.
You could get navigation on the Sync 3. I like it. A lot of people prefer to use their phones.
There is an available sunroof. Some don't want it because they claim it makes the car top heavy and handle worse. Some have had problems with its rain rails leaking.
There were extra cost paint colors, but they are the harder to find colors, except the platinum white.
The biggest thing to look for on a used car other than what you'd look for on any used car is whether it's been modded. Many have modded their cars, and not all modded cars are equally desirable. You also don't know how well the mods were installed.
Exhausts are obvious, and very few of the available catback exhausts are pleasant. Loud, yes.
It has been fairly common to remove the catalytic convertor in the mistaken belief that a straight pipe improves performance. It doesn't. (Exception exists if a large turbo has been installed, but if you're buying used you might stay away from those unless you want to work on the car a fair amount).
Engine mounts are a common mod. Some are good, some not. Increased NVH is part of the motor mount game.
A very common mod is an accessport and tune. Unfortunately, few cars that have been tuned are sold with the accessport. Then the buyer is stuck with a tuned car but doesn't know what it's doing and can't fix it unless he gets an accessport himself.
Intake mods are common. As with any car, a lot of them are worse than the OEM airbox. Buyer beware.
Many have replaced the radiator and/or intercooler. There is a common belief that the cooling system is inadequate. It may well be if you mod the car and use it in high temperatures or constantly keep the revs up by driving around in low gears. On a stock car, you should see no troubles in ordinary driving even in 110 degree high humidity temperatures like we commonly have where I live. In most cases, the aftermarket radiator and intercooler are good pieces, and as long as nothing was damaged during the installation, I wouldn't be afraid of them.
The sound symposer has been deleted on some cars. In states where they check, this may cause some trouble with emissions inspection.
Likewise, some have replaced the blowoff valve.
rallytaff
I have a 2014 and have NEVER had a problem with overheating and was not the subject of a recall. I decided to get a Mountune radiator because they were available this year, not because of overheating.
XR650R
Thanks!
As others have already said, it only comes with a manual. I would get the newest, lowest-miles example I could afford. Check the paint for flaking and rust around seams; under the doors, hatch, antenna and hood.
At this point, any used car is always a guess. You don't know who owned it or how they treated it, modded it, etc. '16 and later ones have the updated Sync 3. '18 and later models have a rear camera.
Look underneath the car. If it has a stock RMM (rear motor mount) and the rest looks unmodified, it was either left stock, or at least returned to stock. I wouldn't be too bothered if it were modded a bit. That in itself doesn't mean it was trashed. Post some pics here if you're not sure. This site is a trove of knowledge.
If you get one, change the tranny fluid immediately with 2 qts. of good synthetic, and change the oil every 5,000, again with good synthetic.
rallytaff
I change my oil at 8,000 miles with a filter change only with full synthetic. No problems.
SteveS
Engine and engine cooling: Engine
Recall date
2017-03-26
Recall no.
17V209000
Ford Motor Company (Ford) is recalling certain 2014 Escape, 2014-2015 Fiesta ST, 2013-2014 Fusion and 2013-2015 Transit Connect vehicles equipped with 1.6L GTDI engines. If the vehicle is started and driven with an insufficient level of coolant within the engine cooling system, the engine cylinder head may overheat, crack and leak oil.
Recall consequence
If the cylinder head cracks and leaks oil, the oil may contact a hot engine or exhaust component, increasing the risk of a fire.
Recall action
Ford will notify owners, and dealers will install a coolant level sensor and the supporting hardware and software, free of charge. Interim notices informing owners of the safety risk were mailed April 21, 2017. The recall began on January 5, 2018. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 17S09.
Check here with your VIN to see if your car was subject to the recall. https://www.ford.com/support/recalls/?gnav=header-support
rallytaff
The only recall I ever had was for the door locks.
