Crankshaft sensor
Putting a new timing belt on 2016 ford fiesta st. 1.6 All the information I can find the crankshaft sensor shows it by the crankshaft pulley, but mine is next to the flywheel, is anybody have this problem?
Rocketst
It should not be by the flywheel.... It should be by the serpentine belt and secures into the block with 1 screw and the sensor itself sits behind the crank pulley. I have a feeling your either looking at the wrong sensor or your car is weird.
Sent from my IN2019 using Tapatalk
H
I will post a picture where I pulled the crankshaft polley off tomorrow
I do find that difficult to believe as the picture I posted is from the FORD Service Manual for the 2016, 1.6L Turbo Fiesta ST.
If it were in a different location, don't you think Ford would show you.
I will take a picture tomorrow
I would like to see this.
Here is a YouTube video as well.
https://www.bing.com/videos/search?...-42&sk=&cvid=5CD7D8F9983D44C8907438B726B3C729
H
https://www.bing.com/videos/search?q=1.6+ecoboost++fiesta+st180+mk7+crank+sensor&&view=detail&mid=0D0A9A7467C47F2511660D0A9A7467C47F251166&&FORM=VRDGAR&ru=/videos/search?q=1.6%20ecoboost%20%20fiesta%20st180%20mk7%20crank%20sensor&qs=n&form=QBVR&sp=-1&pq=1.6%20ecoboost%20fiesta%20st180%20mk7%20crank%20sensor&sc=0-42&sk=&cvid=5CD7D8F9983D44C8907438B726B3C729
H
H
I hope you can see it good enough
Is that engine out of the car?
Is it possible to get a photo from further away to get a better perspective?
Your photo shows that you have the lower pully/balancer off.
Can you provide a photo of the back side of it as well?
H
Come to find out, talked to ford place where we got the car the engine is a dura-tex 1.6 with 16 valves and the crankshaft sensor is by the flywheel
H
Thread Starter #14
No it is not out
H
Thread Starter #15
We are changing the timing belt
Did you buy this as a Used car?
Your first says Fiesta ST.
Are you sure it not an SE?
Do you have a manual or automatic trans; if manual, is 5 or 6 speed?
H
Thread Starter #17
I think it is a se and we bought it new
Well, as an SE that makes more sense.
Make sure you buy parts for the SE and NOT an ST as the parts are different.
You should replace the water pump at the same time.
Other than parts the procedure is about the same.
Good Luck.
