failed smog visual inspection - need to reinstall symposer
Just tune it out brother. People start talking politics my mind shuts down. I dont even hear them. Their mouth is moving but I literally hear nothing.
Yeah, I go on here to GET AWAY FROM all of the at each others' throats incessantly political WARS in this land currently.
There are plenty of sites which I can go on for ideological 'venting' if I need that, just as there are for the 'other side', which so many on here seem to be.
NO NEED to bring that BS in here! [wink]
SrsBsns
San Diego
TemecFist - I'm a few hours away from Temecula, if I was any closer I'd take you up on it lol.
apex1 - Luckily the rubber hose is still attached and was routed behind the battery. I'm trying to buy a used one off a forum member but if anyone near the ventura county area or near the SFV can spare one for a quick test I'd appreciate it!
Where are you located? I'm in SD and you could use mine. I removed it but held onto it just in case I ran into the same problem when I need to get smogged.
ray_bandz0
Los Angeles
Thread Starter #28
Where are you located? I'm in SD and you could use my stock one if you just need it to pass and don't want to have to buy a new one.
Thank you for offering! I just ordered a used one from a forum member otherwise I would.
Anchorage
One option would be to refit a symposer, but just install an internal plug to eliminate any pressure loss.
I had to argue a bit with the classing guys at a couple autocrosses that since there was no flow (even if there was pressure), was just a connection to a comfort/convenience item, and wasn't in the intake pathway, the rule didn't apply. Obviously, tech guy would be different from a ref...
XR650R
Eerie
Thank you D1JL.
Yea it's in California, the guy didn't even know what it was at first. I showed him an article explaining how the symposer is only used to pump sound into the cabin. He read something about the symposer delete needing to be a tight seal to not lose boost pressure and he used that in his argument and didn't back down.
Well, then, he's clearly not a Democrat.
Probably calls himself a libertarian. :p
