- Member ID
- #4208
- Messages
- 1,991
- Likes
- 459
Approval has been granted by [MENTION=2]MKVIIST[/MENTION]to proceed with this group buy.
I would like to start a group buy depending on interest. I have been in the process of making a huge batch of third brake light flasher modules and know the people that have purchased one so far have been incredibly happy.
Why do I need this?
- Grabs drivers attention, responding faster to quick braking
- Reduces chances of other drivers tailgating, lowering your chances of being in a rear-end collision
- California DOT recently required all new vehicles to have a flashing 3rd brake light
How does it work?
There is a microprocessor module with 3 wires, power, constant power and a ground. The module detects when you brake and causes the brake light to flash 3 times before going solid. After 10 seconds it will blink again.
How do I install it?
All you have to do it use a T20 torx bit to remove the 3rd brake light from the spoiler, pull out the wiring, cut the power wire (blue/white) a few inches away from the light connector, splice in the black power wire to the vehicle end of the power wire, splice in the yellow power wire to the connector end. Use the bullet quick splice to add the connector to the black/purple ground wire, squeeze closed and plug in the black wire from the flasher into the bullet connnector of the quick splice connector.
How does the flashing sequence work?
For those wondering how the flash sequence works, check out my video below
Upon initial braking it will flash and then go solid. If you press the brake within 10 seconds after the initial braking it will stay solid. The solid timer resets if you don't press the brake pedal after 10 seconds following that.
So the video shows the initial braking, followed by a following press before 10 seconds and then another initial braking after a 10 second wait time.
Slow flashing
[video=youtube;IZ9UdnDnZGY]https://www.youtube.com/watch?v=IZ9UdnDnZGY[/video]
Fast flashing
[video=youtube;bKb6fU5C08U]https://www.youtube.com/watch?v=bKb6fU5C08U[/video]
The price per module would go as follows, normally sold for $60 each
My goal is to get 30+ buyers in this group buy so that the flashers will be $35 each. This includes shipping and a 3-year warranty. Regular price is $60 per flasher.
Members interested so far, I will keep sign-ups open until we reach the number needed
1)@<a href="http://www.fiestastforum.com/forum/member.php?u=4948" target="_blank">Spaceman_Spiff</a> (1) PAID
2)@<a href="http://www.fiestastforum.com/forum/member.php?u=5992" target="_blank">MikesFiST</a> (1) PAID
3)@<a href="http://www.fiestastforum.com/forum/member.php?u=6197" target="_blank">eddietorr</a> (1) PAID
4)@<a href="http://www.fiestastforum.com/forum/member.php?u=5489" target="_blank">OguNinja</a> (1) PAID
5)@<a href="http://www.fiestastforum.com/forum/member.php?u=2260" target="_blank">SFP</a> (1) PAID
6)@<a href="http://www.fiestastforum.com/forum/member.php?u=4012" target="_blank">Bluedrank</a> (1) PAID
7)@<a href="http://www.fiestastforum.com/forum/member.php?u=2500" target="_blank">FiSTofNoVA</a> (1) PAID
8)@<a href="http://www.fiestastforum.com/forum/member.php?u=6942" target="_blank">Zer0</a> (1) PAID
9)@<a href="http://www.fiestastforum.com/forum/member.php?u=6392" target="_blank">mattyboh</a> (1) PAID
10)@<a href="http://www.fiestastforum.com/forum/member.php?u=4127" target="_blank">BionicBarnacle</a> (1) PAID
11)@<a href="http://www.fiestastforum.com/forum/member.php?u=6958" target="_blank">ZeroMmx</a> (1) PAID
12)@<a href="http://www.fiestastforum.com/forum/member.php?u=688" target="_blank">Sourskittle</a> (1) PAID
13)@<a href="http://www.fiestastforum.com/forum/member.php?u=5026" target="_blank">deranger</a> (1) PAID
14)@<a href="http://www.fiestastforum.com/forum/member.php?u=6967" target="_blank">FordST</a> (1) PAID
15)@<a href="http://www.fiestastforum.com/forum/member.php?u=6968" target="_blank">insertnamehere</a> (1) PAID
16)@<a href="http://www.fiestastforum.com/forum/member.php?u=6970" target="_blank">DartheSuite</a> (1) PAID
17)@<a href="http://www.fiestastforum.com/forum/member.php?u=1650" target="_blank">Pete</a> (1) PAID
18)@<a href="http://www.fiestastforum.com/forum/member.php?u=5701" target="_blank">goldygopher</a> (1) PAID
19)@<a href="http://www.fiestastforum.com/forum/member.php?u=2404" target="_blank">TrickSTer</a> (1) (Canada) PAID
20)@<a href="http://www.fiestastforum.com/forum/member.php?u=3130" target="_blank">gongos</a> (1) PAID
21)@<a href="http://www.fiestastforum.com/forum/member.php?u=6868" target="_blank">B_Rad_ST</a> (1) (Canada) PAID
22)@<a href="http://www.fiestastforum.com/forum/member.php?u=1282" target="_blank">Sir_Stig</a> (1) (Canada) PAID
23)@<a href="http://www.fiestastforum.com/forum/member.php?u=5059" target="_blank">RED RYDER</a> (2) PAID
24)@<a href="http://www.fiestastforum.com/forum/member.php?u=6716" target="_blank">lordgeese</a> (1) PAID
25)@<a href="http://www.fiestastforum.com/forum/member.php?u=6968" target="_blank">insertnamehere</a> (1) PAID
26)@<a href="http://www.fiestastforum.com/forum/member.php?u=7002" target="_blank">sidewaysallday</a> (1) PAID
27)@<a href="http://www.fiestastforum.com/forum/member.php?u=2529" target="_blank">Ext569</a> (1) PAID
28)@<a href="http://www.fiestastforum.com/forum/member.php?u=6513" target="_blank">JaMuLi</a> (1) PAID
29)@<a href="http://www.fiestastforum.com/forum/member.php?u=6194" target="_blank">mattw</a> (1) PAID
30)@<a href="http://www.fiestastforum.com/forum/member.php?u=4851" target="_blank">trahma</a> (1) PAID
31)@<a href="http://www.fiestastforum.com/forum/member.php?u=5570" target="_blank">Silo</a> (1) PAID
32)@<a href="http://www.fiestastforum.com/forum/member.php?u=3847" target="_blank">dFaktor</a> (1) PAID
33)@<a href="http://www.fiestastforum.com/forum/member.php?u=6284" target="_blank">brbauer2</a> (1) PAID
34)@<a href="http://www.fiestastforum.com/forum/member.php?u=5343" target="_blank">Fist_Mark</a> (1) PAID
35)@<a href="http://www.fiestastforum.com/forum/member.php?u=5043" target="_blank">imhenry66</a> (1) PAID
36) @<a href="http://www.fiestastforum.com/forum/member.php?u=6537" target="_blank">HunterLayne</a> (1) PAID
37) @<a href="http://www.fiestastforum.com/forum/member.php?u=1258" target="_blank">LT Berzerker</a> (1) PAID
Total flashers so far: 38/30
Accepting sign up until January 31st, asking for payments after sign up.
Why do I need this?
How does it work?
Slow flashing
Fast flashing
