MRX Short block aux fuel
Status
Not open for further replies.
Minnesota
Building and soon to be done from CPE. Looking for some Minnesota FiSTers to drag and ride. Thanks MKVIIST
MRX330
Minnesota
To start off my car was at 105k and I was getting ready to open it up to change out the timing belt. I also wanted to put in the MRX turbo. Then I thought a ported exhaust manifold wouldn’t be such a bad idea. So here is my build: So I reached out to Mitch at CPE and we hashed out what I was trying to do. I wanted forged internals but then realized boring out the block isn’t the best idea. Then out of nowhere the Mountune short block was available. Well this killed 2 birds with one stone. Forged internals properly set up and balanced by Mountune’s Brit engine builders. I shall continue
MRX330
Minnesota
Engine: Mountune short block, new Ford cylinder head, ARP head studs, Supertech MLS head gasket, Mountune V2 cams and springs, MRX turbo(hot side Cerakoted), Mountune billet 17lb wg actuator, ATP SS oil/water lines, Vudu 42mm ported exhaust manifold (Cerakoted), Mountune dp (Cerakoted), Stratified 4 port aux fuel, new coil packs and injectors, NGK iridium plugs, Mountune radiator, Samco coolant hoses, new water and oil pump, alternator, RSport baffled oil sump, new timing belt
Tuning: 91/93/E50 by Mitch Levy @CPE
Intake: Mountune full intake, RamAir crossover pipe, 2.75 to 3” coupler into MRX, Samco silicone hoses, CPE fmic, Mountune TurboSmart Kompact BOV
Chassis/suspension: Powerflex transmission and upper engine mount inserts, front/rear spring pads, rear beam to chassis bushings, front sway bar bushings, new lower ball joints, Hotchkis front end links and rear sway bar, CPE rmm, Bilstein B8 shocks and struts, Mountune linear springs, Mountune SS brake lines and street pads
Mountune strut tower and lower chassis braces
Oil/fluids: Joe Gibbs Driven DI 0w20/5w30 mix, RBF600, BG transmission fluid,
Exhaust: Thermal R&D (Cerakoted), Mountune exhaust hangers
Exterior/Aero: Mountune front splitter, Zunsport lower grill, Phillips Xtreme Vision low/high beam and fogs, Hella Supertone horn
Wheels: Rota Titan Gold 17x7.5 63.4hb w/Michelin AS/3+, Rota Grid Hyper black 17x8 63.4hb w/Dunlop Direzza ZIII, Gorilla splined gloss black lugs
Interior: Boomba plain black Delrin weighted shift knob, Redline Goods black Alcantara shift boot and arm rest cover with yellow double stitching, Valentine V1
Soon: MFactory LSD, Spec clutch, new wheel bearings all around, CFM valve cover breather lol and Bluetooth ethanol sensor
Saint Pauly
Well I too am from the Land of 10 k lakes......Welcome to Thunderdome! Id like to see that vehicle up in action sometime. See what its all about.....Good luck!
MRX330
Minnesota
I’ll be around in the summer. I don’t do Facebook so if there’s some sort of meet coming up let me know.
Saint Pauly
You in the cities? We have the group here on the forum also..... check it out.
MRX330
Minnesota
Where’s your build thread? I need to know what Im up against. I know you have a big snail and cooler.
Saint Pauly
Like what Dude? Let the cat out of the bag man!
A bunch of Rando stuff.... you can see my car on a couple of the vendors web sites from the forum though....
MRX330
Minnesota
Thread Starter #16
Do these things make power or are they cosmetic shiny bauble thingys?
Saint Pauly
Just remember that Power corrupts......Horsepower corrupts absofuckinglutley. Are you gonna go to BIR Proving poop?
Saint Pauly
The little boys drive their pocket rockets around and do dub-step crap and make s'mores around the campfire in the ZOO. While the Big boys get tore down! I Might go.....depends on if I'm driving to Cali In the FiST that month...I haven't decided and neither has the BAE.
MRX330
Minnesota
Thread Starter #20
Is it a race man? Either way I won’t be in Mosquitosota until the beginning of June. When is this happening?
Status
