Powertrain Warranty Questions
1.6
Chicago, IL, USA
Both of my axle seals are leaking and my clutch master cylinder just started leaking as well. 2016 with 29,000 Miles. I only have the powertrain warranty left.
From looking at the forum, the axel seals should be covered under powertrain but what about the clutch master?
Has anyone had any luck getting a dealer to cover that under powertrain?
Pics Attached
I don't think you should have an issue with either. It's a 5 yr. 60k powertrain coverage from New* Let us know if you encounter any issues.
1.6
Chicago, IL, USA
Dealer is saying axle seals are covered but not the clutch master leak. Has anyone that was only on the powertrain warranty have a dealer fix anything with the clutch master?
