Shift Knobs and Reverse Adapters - Multi Combo's and Colors Available for FiST
BoostBumps
Arizona
Thought this might be of interest...
For anyone interested in creating a unique custom 2 1/8" Shift Knob w/ Reverse Lock-out combination for a reasonable price....
http://www.cjponyparts.com/catalog/category/view/category/70000396/id/2482/?limit=60
Reverse Lockout Adapters (Black or Clear Anodized):
Broad Range of Knob Colors and Design Combinations Now Available:
JPGC
Middleburg
Nice find!! That opens up a lot of possibilities for everyone!
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
I believe that these are the same items as sold by Speeddawg.
This could very well be true as Speeddawg has hundreds of distributors.
My point is that the adaptor is not cupped deep enough for a round ball.
That is to say that there is almost a 1/8 inch gap when/where the ball and adaptor come together.
You can just barely see this gap in the photos above but I have seen it up close.
This by no means will prevent the use of these products.
It is just in my opinion it looks incorrect or unfinished.
Dave
BoostBumps
BoostBumps
Arizona
This Reverse Adapter "cup" looks to have sufficient enough depth to seat the bottom of shift knob properly and appears well seated as far as I can tell...Although I suppose there could be a chance where a space might appear if a smaller diameter shift knob were to be installed along with this adapter...However, I'm not seeing an 1/8" gap in the close-up pic (below) when installed with these slightly larger 2 1/8" dia. shift knobs...
BoostBumps
BoostBumps
Arizona
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
I will try to do a photo after work today.
From a lower angle you will see it.
In the meantime look at the photo of the green one closely.
Dave
BoostBumps
BoostBumps
Arizona
Dave
Oh? Do you already have one of these adapters Dave??
I also took a closer look at the green knob image (below) and looks to me like they simply didn't screw the knob all the way down....
Compared to this image...
[HR][/HR]
On a side note...wonder how well this adapter would work along with a standard shifter extension?
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
Trust me,
It looks that way when it is tight.
It should work perfectly with a shifter extension.
I will measure it as well tonight to be sure.
Dave
BoostBumps
BoostBumps
Arizona
Trust me,
Dave
thanks Dave!
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
As promised here are the up close photos of the adaptor along with a Speeddawg ball.
They are tight together on a Fiesta shaft.
The size is 1.300 inch inside diameter and 1.425 outside diameter.
Dave
BoostBumps
BoostBumps
Arizona
Thread Starter #13
thanks Dave!...What size diameter is the knob?
Baton Rouge
Do they have to use that aluminum piece? What is the adapter for? You can't just unscrew the factory knob (which I quite like, btw) and screw on something else?
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
The adaptor is just a place for the reverse lock out to go.
I guess you could do without it if you like.
Dave
Victoria
Hi guys! Just want to know if you think other shift knobs would fit? I want to make my own shift knob but the bottom would be square and fairly large.
CanadianGuy
Southern Ontario
Are you making your own? If so you could bore out the bottom the size of the lock out and use thread lock to keep the knob from spinning. I do have the same idea as Dave does the adapter for the lock out is $17 from CJ pony parts or you could also use the Dead Hook Motors shifter extension (found on this forum)
Victoria
Well the Dead Hook Motors shifter extension would make it look weird because its going to be a Samurai sword hilt. If I start making a hole in the guard of the hilt, the guard won't fit on the handle anymore. My final result should look a bit like this:
http://www.dndperformanceinterior.c...bs/products/samurai-shifter?variant=105138186
CanadianGuy
Southern Ontario
Then you need something like this.
http://www.cjponyparts.com/shift-kn...-v6-gt-2011-2014-boss-302-2012-2013/p/HW3291/
BTW that is kinda cool.
