***Update*** Jump to page 3 for detailed revisions.
Ok. Let's face it. The Sony stereo sucks. We all know it. It's poorly thought out and even more poorly executed. The sound is flat, even with the adjustments maxed, your arm blocks the drivers side tweeters if it's up on the window sill, the sound stage is too low and wide because the tweeters are too far back in the door, etc. etc. Most glaring of all is the lack of bass. There are lots of threads on sub upgrades around here but this is mine. A little background on me, I was an IASCA competitor and SQ judge back in the mid 90's with sponsorships from Streetwires and Oz Audio. I used to dump a lot of money and resources into cars to win trophies. This is not one of those systems. I am much older and, currently, much poorer. If money was no object I know all the things I'd do to make the cabina place of sonic euphoria but this is a test to see how much improvement in sound a minimum investment can make. Also, I wanted to have the entire system fit under the rear cover with room still for my road emergency kit, Get Home Bag, and California Car Duster. All this plus a cost of under $100. I knew I'd be sacrificing on some things, which kills my soul after what I'm used to running, but taking a hit on brand snobbery was worth it to improve my daily commute. So here goes...
Sub - Boss Audio CXX8. 8" subwoofer, "600" watts, 4 ohm SVC, seals in .35. cubic feet. $26 on amazon.
Amp - SoundStorm SMCM200. Monoblock, 2 ohm stable, 200 watt class A/B amplifier. $29 on amazon
Wiring - Boss Audio Kit Zero 10 gauge wiring kit. $10 on Amazon
Wood - 2x4' sheet of 1/2" MDF. $10 at Home Depot
Carpeting - Roll of black automotive carpet. $10 at AutoZone.
So, all in all I'm on the hook for about $85 in materials, about half the price of a cheap super shallow powered sub. Granted, I had other things like glue, fasteners, RCA block, etc on hand that would add to others' cost, so YMMV.
I used the calculator at carstereo.com to figure out my box volume. I made it just big enough to tuck in by the passenger side rear tail light. External dimensions were 17" x 10.5" x 5", giving me an internal volume of about .35 cubic feet for a basic rectangular box. I have the ability to upgrade a small volume (~.5 cubic feet) 10" sub down the road if I want to build an L-shaped box to use wasted space around the rear hinges for the cargo floor, but in the interest of simplicity I went basic for now. I constructed the box using Gorilla glue and an 18ga finishing nailer. I figure that this should be adequate for a cheap 8" and would save the risk of splitting the thin MDF with screws. If I move to a 10 I can always go back and pre-drill/screw it together between the nails then.
Tomorrow I'll wire up the amp and get it installed and we'll see what happens.
