TB 4-Pt Brace Install - HELP!
Wichita, KS, USA
I'm trying to install this 4 point solo and I cannot get the lower control arm bolt-holes to line up at all (the fronts and rears). I have the passenger side front facing bolt in, but the driver side just will not line up. I've tried jacks, ramps, a small pry bar, nothing is working. Does anyone have suggestions or a video link that details this thing? Getting seriously frustrated.
Thanks.
green_henry
Pleasant Hill, CA
Do you have all four corners on jack stands or only the front? If only the front, borrow some for the rear and let us know if that helps
FJ16
Wichita, KS, USA
I just have the front. Would the rear really have any effect on the front suspension?
green_henry
Pleasant Hill, CA
I just took a look at TB's pictures for the "Torque Gusset Traction Bar" and they show it on 2 jack stands, so it may not be worth the effort -- but can't hurt.
you are supposed to have the wheels on ramps. Suspension needs to be loaded for instal If you let your control arms hang it will not be preloaded.
Thats the way the other brands suggest doing it.
I did my Summit Swave on a rack and if I needed to shift the control arms slightly we used a tranny jack to give a little lift. Though both wheels were on a flat surface. Took about 10-15 minutes max to install.
Ford ST
Pleasant Garden
I'm going to say it like this we don't install suspension components in shops on ramps it is done in the air.
I do recommend doing the final tightening with the vehicle loaded on its wheels.
To each their own.
FJ16
Wichita, KS, USA
Yeah it's on ramps, I'm just having trouble manipulating the control arms to line the hell up.
ya put a jack under your trans or the and jack it up a little just like I described with the tranny jack. It might have been the subframe jacked up a little . If you look at my install thread mini review you will see.
To each their own.
I would agree except this a brace, While it attaches to suspension points much like a swaybar it stiffens and quite a few performance shops and aftermarket companies recommend installing with preload. Which is not hanging in air.
I also would say that when I installed my Hotchkis rear swaybar it also said to install with the wheels on a surface rather than in air. Straight from Hotchkis!
All is not the same with Performance sometimes.
Ford ST
Pleasant Garden
My personal opinion on that they are just saying that because they actually want you to do the tightening with the wheels on the ground.
Maybe it would be a little more time consuming for them to explain jack up car install bolts loosely, and lower on ramps tighten to torque specs.
Whatever works for you.
