Won’t start just cranks
My car won’t start just cranks coils all firing , fuel pump working, timing is all good , has compression anyone have any ideas I can try
How old is the battery? The System runs on CanBus and need to have correct voltage to start. Start out there....Report back.
J
The battery is 2 months old in the car
Get it checked anyways. I have seen batteries shit the bed in a matter of days. Pallets of batteries from the manufacturer that are all Bad out of stock and get re-called. It's worth covering your bases.
J
Checked the battery checked out fine
J
If the battery tests fine, check the camshaft position sensors.
Sent from my H8314 using Tapatalk
Yes checked the camshaft & crank shafts sensors going to check the high pressure pump out tomorrow
