Engine oil level above max mark on dipstick
YIN
My car was oil changed last week.
I checked the dipstick yesterday (parking outside whole night), just found the oil level above max mark around 5mm( drowning that small triangle).
Is this likely to do any damage to engine?[confused]
CanadianGuy
Did you measure the engine hot or cold? dead level or was the car on an incline?
I don't know about this car but in any other vehicle I have had a little too much oil no damage was ever done.
Lastly I always measure 3 times cleaning the stick each time just to be sure.
Plainrt
Wish I had that dipstick. Think mine harder to read
YIN
YIN
I measure that both cold and hot without incline. (the picture I posted was cold). I measured it over 5 times........still over max.......... [bigcry]
Its perfectly ok. If you were an inch up the stick I would go back, but you have about 300ml overfill, so it is nothing to worry about.
YIN
YIN
Awesome!
Thanks , Buddy~
Chuckable
Not to make you worried, but I believe somewhere in the manual it says that an overfilled engine can cause engine damage! In truth, though, like blurred said, you're so little over the full mark I wouldn't even worry about. But, if it bothers you, take it back to where the oil change was done.
YIN
YIN
Thank you for reply .
Anyway, I will change oil earlier than usual, just in case. :)
YIN
YIN
[twothumb]
Butterybunz
Mine is similar to yours. I'm not worried about it. I did full synthetic and for the life of me could not read the dang dipstick when the oil was brand new! Seriously, held the dipstick under a LED light and could not read it. I hate the dipsticks in these cars.
Chuckable
Heard that Cravenspeed may be making dipsticks for the FiST.
If you guys are having such trouble reading the dipstick, try the ol' napkin trick!
Just dab the dipstick on a flat paper towel or something, spin the dipstick away from the dab and it'll tell you the level. Seems crude but works in a pinch.
The added pressure under WOT or hard driving can blow out the seals, but I've never had it happen and I've had it overfilled before by 3rd parties. Now I just take my car to Ford and they always get it right. I have a good dealer.
Hijinx
Drain some oil immediately.
Like CriticalmassGT said, it can blow a seal. Little did I know a quick change place overfilled me. The level was about a half inch above the top level. Long story short, when it's over-filled, the oil can't drain from the turbo, and with the added pressure it kills the seal and causes an oil leak into your exhaust.
Sourskittle
Beat me to it :)
YIN
YIN
Already did it last week。Thx。
so I recently bought a 2016 fiesta st I did an oil change at 4000 miles using mobile 1 full synthetic. my car now has 5000 miles on it I checked the oil today and also checked to make sure the vehicle didn't have any blow by in the top end. I removed the oil cap while the engine was running and put my hand over where the oil cap would be. and I did in fact feel some pressure coming through. I don't run the car hard and I was just wondering if this was normal. im very concerned about this and was wondering if anyone else has ran into / heard of this before. a response would be greatly appreciated. thanks!
razorlab
Absolutely normal
Seriously!? I was freaking the heck out. I was always told there should be little to absolutely 0 blow by. I also noticed that when I pulled the cap very very faint white steam was coming from the cap. Is that normal as well?
