DHM EFR Turbo Kits!!! Finally here!!!
Trader history for DHM (0)
DHM1
Royal Oak
We are very proud to be releasing the first Made In The USA Fiesta ST EFR Kit. We have two versions on rated at 280whp on 93oct and one rated at 320whp on 93oct. Dead Hook Motorsports plans to be the leading force in Fiesta and Focus ST development and this is just one tiny step toward that goal. Stay tuned!
DHM280 EFR Turbo Kit #20001
All DHM Turbo Kits are rated at wheel horsepower available on 93oct! Our kits allow for a simple OEM like install. NO modifications to the vehicle or OEM parts to complete install. Custom tuning available in house!
- DHM280 Fiesta ST expectations
o 270-290whp on 93oct (22-24psi)
o Spool time 3450-3700rpm to full boost
o Flat torque curve from 4k to 7k+
o Peak Hp 6000-7000rpm
o 3000+rpm of usable peak power!
o Good drivability builds boost quick at low rpm in 6th gear for passing
o Everything the car should have been from the factory!
- Borg Warner 6258 EFR Turbo Charger
o Ideal for use in single turbo applications for the 260-440hp range
o Built-in BOV: All EFR compressor housings incorporate an integrated BOV.
o Compressor Housing: 2.5" inlet, 2.0" hose coupler outlet.
o The EFR 6258 is the smallest and fastest spooling EFR turbocharger in the lineup
o Compressor Type: Forged-Milled Wheel (FMW) Extended Tip
o Turbine type: Low Inertia Gamma-Ti Turbine Wheel
o Stainless Steel Turbine Housing
o Turbine outlet: GT-Vband (aka small 3" vband) ~92mm OD for all EFR turbos
o Dual Row Ceramic Ball Bearings - lowest friction and fastest spool/response, most extreme durability, built-in oil control orifice
- DHM Stainless Steel EFR Tubular Manifold
o 1.25? Sch10 304 Stainless Steel
o 304 Stainless ?? Thick T25 Turbo Flange
o ?? Thick CNC Mild Steel Cylinder Head Flange
o Hand Made 4-1 Merge Collector
o 100% TIG Welded and Back Purged
o Premium Port work and Hand Blending
o Made in house in the USA!
- DHM Stainless Steel EFR Down Pipe
o 100% 304 Stainless Steel
o OEM Fitment to Exhaust
o Quality Flex with Internal Liner
o Made In house in the USA!
- DHM Aluminum EFR Intake and Charge Pipe
o 100% TIG Welded
o OEM Fitment
o Bead Rolled Ends
- All hardware needed for complete install
o High Strength Studs and Nuts for Turbo to Manifold
o Stainless Steel T25 Turbo Gasket
o OEM Fitment Oil Feed and Return
o OEM Fitment Coolant In and Out
o 4 Ply Black Silicon Couplers (Red or Blue on request)
o Borg Warner EFR V-Band Clamp
o SS T-Bolt Clamps for all hose connections
o Thorough Instructions
o Ceramic Coatings Available (Email request)
o EGT, EMAP , Compressor wheel speed, Pre intercooler temp, etc available (Email request)
o TurboSmart BOV and Wastegate upgrade (Not Included) (Email Request)
Any questions regarding our DHM turbo kits please contact [email protected] . We will have chassis dyno results soon!
http://www.deadhookmotorsports.com/product-p/20001.htm
http://www.deadhookmotorsports.com/product-p/21001.htm
Hope you guys like it!
Russ
Sourskittle
Lakeland
What's the difference between the 280whp and 320whp versions?
Stuff looks awesome !!
DHM1
DHM1
Royal Oak
Amazing kit Russ!! Do we know if the stock clutch can handle this setup?
It should Sourskittle has been on a stock clutch for some time now at power 250-280whp. Rick which bought the first kit is on a stock clutch as well. I will hopefully be testing more soon.
Russ
Sourskittle
Lakeland
I put 354ft. Lbs of torque to the stock clutch for a week or so, and that's instant donkey kick torque, not "build as we go torque". So I think it will handle it, at least short term. No way to know long term. I've been impressed with it though, I'm not easy on the clutch/car AT ALL.
I had a guy with slicks tell me he sold his fist and bought a mustang because the fist clutch couldn't handle a stg1 power level on slicks. But.... He's the only one I've heard of.
DHM1
DHM1
Royal Oak
I run 320ft/lbs on our fist all day every day. I run slicks every other week to. Never had it slip once
Sounds like a reasonable reason to switch cars. Guy sounds bogus lmao.
pwnall1337
Vendor
San Antonio
Is there money to save if you opt out of the charge pipe/intake pipe for people that go with an aftermarket intake and aftermarket intercooler?
DHM1
DHM1
Royal Oak
I'm very confused by this. This is a Borg Warner efr so the parts included are to fit to the turbo. The stock turbo set up is completely different. Also this charge pipe is meant to go to the stock hose so it does not affect what intercooler you have. This will be sold as a kit. Unless you plan to fabricate and or modify other parts to fit.
DHM1
DHM1
Royal Oak
The pipe was designed to fit with the stock intake. I would imagine that most aftermarket intakes would fit with little modification.
