Perfblue15
Umm quick question Raam. How much work is needed to get the jline in the car? Im not going to need to cut half my front end am i. Just asking because i have a jline coming from some Rick guy and just making sure my car wont have to be out of commission for longer than a few hours to a day if i were to be also installing a new turbo to go with it.
Thanks
Honestly its a super easy install. The only real modification needed is making some simple L brackets to attach the ic and turning some holes in the bumper into bigger access holes to allow you to get attaching hardware and your tools inside the bumper support. The only stock part i ended up not using was the plastic shield for the bottom of the bumper. Because honestly the j line is so big theres no room. Also mount the ic upside down with the mounting bolts facing up everything lines up perfect that way. It really is a simple install anyone with car modding know how can get it done in an afternoon.
Last night I swapped my stock antenna for the Perrin 2", and also swapped in the Cobb rear motor mount.
stuntdoogie
It's night and day. LOVE it! Should be mandatory for every ST owner. Gear changes are much smoother now, and I don't notice an increase in the vibration idle at all.
Thanks, i have one just never got around to installing it yet.
stuntdoogie
Oooops laggy double post
I had my new wheels installed. Rota Grids 17x8 +40 with stock tires paired with Mountune sport springs. No rubbing from lock-to-lock (what a relief, haha).
MKVIIST
MKVIIST
Thread Starter #1,595
Perfect wheel choice Stephen, looks beautiful.[perfect10]
Thanks guys! I'm very happy with how they fit. The rims are perfectly flush with the fender. I can't wait to slap some 215s on them. [wiggle]
