U.S. Navy Veteran
SFV, So.Cal.
Thanks man. Definitely doing that. On another note, I hate how they say this product doesn't fit 2014 ford fiesta. So annoying.
You need to read as to what you are buying.
It is not the lug nuts that don't fit the FiST.
It is the VALVE STEMS.
Yes, I know they will work if you remove the TPMS.
Dave
Kip2MyLou
Gaithersburg
Dave
I'm just talking about the lug nuts. That's all they're advertising as selling correct?
U.S. Navy Veteran
SFV, So.Cal.
From the Amazon AD:
1.24" Overall Length
• M12 x 1.5 Thread Size
• 13/16" Hex Size
• Tuner Style Cone Seat Wheel Installation Kit
• Set of 12 Lug Nuts, 1 Installation Tool, 4 Wheel Locks, 1 key, Key Storage Pouch and 4 Valve Stems
Dave
Kip2MyLou
Gaithersburg
From the Amazon AD:
? M12 x 1.5 Thread Size
? 13/16" Hex Size
? Tuner Style Cone Seat Wheel Installation Kit
? Set of 12 Lug Nuts, 1 Installation Tool, 4 Wheel Locks, 1 key, Key Storage Pouch and 4 Valve Stems
Dave
Once again I fail at reading...
St. Peters
Opened up the shroud for the intake like Blue Bomber advised. Haven't driven yet, but it should do something good lol.
Carson City
You might be a bit more addicted than I am buddy!
I have been working on that issue, thought I would barely mod this car......looks like group therapy may be in order:)
rodmoe
wausau
I can justify this under household items as it may go a ways to keep the valves cleaner is one of my hopes.. hehe
iso100
Bone dry. I did this at golfguy11800's house. I was surprised to see zero oil after 9k. I don't baby the car...
Baltimore
Remove the headrest, on the side that there is not a headrest adjust button there is a little button in the plastic bezel that faces the outside of the seat, use a flashlight to find it and a small flat blade screwdriver to push it in. This allows the headrest to come completely out of the seat. You will need to have the seat leaned way back to do it. Once I had it out, I clamped it by the legs to the side of the bench with two c-clamps and piece of 5/8" Baltic birch plywood. Clamp it so the headrest is almost against the bench, and make sure the plywood on the front side of the clamps is almost up to the headrest as well. Then I stuck a smaller piece of the same plywood in the jaws of the seat clamp to make a fulcrum point. I used a 3' pipe as the lever, and another piece of plywood between the headrest and the pipe to spread the load on the headrest. Then it's archimedes to the rescue, it took 1.5 people pushing to get it moving. We did one side first, in basically three increments to get the amount of bend right, then used that as a template to match the other one too. Go slowly, and make sure you are bending it squarely. We got a little off and it was easy enough to shift the pipe over to the side that was underbent to square it up again. It's a little time consuming because you have to keep installing removing the headrest to get the right amount of bend, but it's easier to go a little farther than to realize you have gone too far.
The arrangement looked like this:
The result is this, this is the passenger side in what is now the all the way down position.
