PULSE! Third brake light modification
U.S. Navy Veteran
SFV, So.Cal.
Updated the video to show the initial pulsation and then what happens after you tap immediately after, then how it pulsates again after 10 seconds.
The one I use does that as well.
So people just have more options.
Dave
jeff
Evans
OK I received and installed mine today, thank you for the quick shipping. Took a little longer for me because there was literally only 1 inch of wire exposed from the car once everything was disconnected, very short! but with a little creativity I got it taken care of and the results are quite nice. Thanks again for making me aware of this mod, it's a great one for sure.
OffTheWall503
OffTheWall503
Memphis, TN
Thread Starter #30
I'm glad it works well for you! It's a great mod for sure.
Pittsburgh
#35
This is where I bought mine http://www.3rdbrakeflasher.com/brake-light-flasher-c-65/. The pulses are completely programmable (speed and number of pulses). It also has different timer options that allow it to delay in traffic. Literally took 5 mins to install and only $20. They even have another pulsator with less options for $15. Can't beat it.
http://youtu.be/5h6KJ4J3W3I
I have my pulse set so fast that the camera doesn't pick it up well.
CanadianGuy
Southern Ontario
#36
Hmm I like options. If the plug and plug one for the mustang is a no go this is a good option. How is it programmed?
Pittsburgh
#37
jeff
Evans
#38
Looks like there are some good options out there. $50 is a lot to pay for a few components and wires, $20 is more like it. Still I like having one that comes with connectors and has the circuit protected and insulated and does not need to be programmed.
Either way this is a great cheap mod that has made my day!
jeff
Evans
#40
Hey just another review/thought after a week or so with this mod....
1. People have DEFINITELY backed off especially at stops. It is noticeable. The Pulse piece that I got (opposed to other similar modules) has a pretty mean/aggressive flashing burst that communicates BACK OFF! Not placebo - multiple people have gotten behind me at a light and stayed about 8 feet from the car where before people would pull up much closer. This is great.
2. While I think this is a great mod I think that if the plug and play option that some are looking into becomes an option, it is a much better way to go, especially if it was the same price. That way there would be no issues installing. You might remember from my previous post that I had such a small amount of wire play I decided to solder the connections for longevity. But if a plug and play option becomes available it would be the way to go, as I don't see the average car owner want to solder in such closed quarters.
Thanks again OP for raising awareness of this great mod.
[wrenchin]
