Novice Guide to Autocross
Admin1
Introduction
Some of you may be asking yourself this, maybe you've never heard of autocrossing, or you have but don't know what it is, well hopefully this little write-up will clear all of it up for you.
What it is
"Solo II is a precision sport, much like, say, archery, riflery or golf. You must be precise and consistent, all the while driving so fast you can barely concentrate"
Solo II events (also known as autocrosses) are an all forward motion driving skill contest. Each driver is individually timed to the thousandth of a second, over a short, miniature road course clearly defined using traffic cones. Cars compete one at a time, hence the name "Solo", in a class with similar cars. An event can be held on any flat paved surface, usually a parking lot, or airport apron or runway.
Working
At each event, if you race you will be required to work a heat. This involves standing at a station on course and getting one of three assignments. Cone person, radio person, or flagger. If you are cone person, you must watch each car that goes through your section of track carefully. If they do so much as even grace a cone you must run out and check it. Each cone has a designated box marked in chalk around it. If the cone is knocked over it's an automatic penalty, if it is still standing but touching part of the box, it is safe, no penalty, replace the cone back in the box properly, and if the cone is still standing but outside of the box it is a penalty. In all of these cases be sure to tell the radio person if it is a penalty or no penalty. As radio person, you receive commands from the trailer and radio in penalties on cars if they hit a cone. As flagger you have a red flag that you must wave in case of an emergency, i.e. a broken down car on course. It is your job to ensure the driver sees you and comes to an immediate halt.
Cone penalties:
Course of day
-Registration
Show valid driver's license, and membership card, or get buddied in, and pay the fee. Then, sign the waiver and sign up for working.
-Clear your car
Take out the spare tire, jack, and any miscellaneous items in the cabin.
-Tech Inspection (Can be done at any time before you race)
Take your car to the tech area and have an official check it out. When they are done, they will sign off on your grid card. If you brought a helmet with you have it ready. (If you race in the first heat you tech on grid)
-Course Walk
Walk the course as many times as possible before the Driver's Meeting taking it all into your head and thinking about how you're going to drive it. Try to memorize it. First-timers might also want to take a novice course walk.
-Driver's Meeting
This is mandatory for all drivers and is held about a half hour before the first race. They will go over course conditions, how many heats, etc...
-Your Runs (you might work before you run, it all depends)
SF Region Solo 2 events normally give three runs per driver. Drive your car over to the grid and pull up in any of the lanes as far as you can. Put your grid card on your windshield underneath the windshield wiper blade. Once the lane next to you starts to move get in your car and start it to get it warm.
-Your Work Assignments
Report to work as the heat before your work heat is drawing to a close. As a novice, someone will go out with you to help you get used to working.
-Fun Runs
If heats finish early and the administrators feel there is enough time they will conduct fun runs. These are not counted for points but are simply just to go through the course a few more times and get some more experience trying to bring your times down.
-Course Clean-Up
The biggest thing they like is if you stack some cones, it really helps them out in the clean-up process, and anything else they may ask.
Etiquette
Solo 2 is a social sport, and most drivers are happy to give you advice and critique your runs. Ask someone with a similar car if you may follow them through a course walk. Maybe they'll even think aloud for you (don't do too much talking yourself, or you will be making them walk again). Ask if you can ride with them on a fun run, and offer to pay the $1-$2 for the run. If you're not sure when to line up, go ahead and ask. Ask someone to look at the chalk on your tires to see whether you need more air. Ask someone to watch your run if they have time, and tell you what needs changing. They'll be glad to.
There are a few bad times to ask for advice, though. Here's a quick list:
When they are walking the course. (They're trying to memorize it.)
When they are staring into space or have their eyes closed, they're probably going over their run or plan.
When they are in grid. They are only thinking about the course.
Sometimes events will conspire to keep a good driver from competing. It may be a broken car, it may be an injury that prevents them from being able to change tires. This is your chance! Offer that driver a ride (co-drive) in your car - make it free if you can afford to. So they use up $20 worth of tires. Not a bad price for a private instructor all day! I have gone to some of the big events, Tours, Divisionals and ProSolos and sent out an ad for a co-driver. It has been an enourmous benefit to have advice from these experts all day, and be able to walk the course with them.
Try to help out. There is more work to be done than the mandatory course-work. This is an all-volunteer organization, so help is always appreciated. Luckily, this also puts you in a position to talk to other drivers, because the veterans are helping out, too. If you share the work, they'll have more time to talk to you. Likewise, showing up early will help out the registration and tech crew, and give you more time to walk the course. Read the next section on how to help, if you're looking for ideas to lend a hand.
Everyone stays to help clean up the course and pit areas. Keeping the sites is important to everyone, so leave your pit area cleaner than you found it.
Perry
Sounds pretty cool. I take it no mods are necessary/expected for the cars? How does one find out more about this sort of thing in a given region?
Perry
Thanks for the help, everyone! [8] I've discovered a novice autocross course put on by the KC Region of the SCCA in April. By summer I hope to have some idea of what I'm doing in it.
rodmoe
Any change you get is worth the effort even if you hit a cone keep after it and work on your lines .. slow in is fast out and remember this car loves to set the tail out if you life mid corner so get comfortable and use that to help you zing thru the tight corners ..
Perry
Thanks, rodmoe. I figure I can also get practice trying to run and hide from cars with flashing lights . . . [burnout] [kidding]
rodmoe
LOL yup then you will learn all about waiting between runs :)
Colin1337
Nice write up! Ive never done this before so ill def be rereading this before my first event.
Perry
I hadn't thought about the Porta-Potties. I may have to rethink this. Beats adult diapers, though, I guess.
Perry
No, no--just extending the joke. Or trying to. Ther's a reason I don't make my living in stand-up. The truth is I've not had a ticket in years, and never many.
rodmoe
I can't recall being asked or carded for a lic. Was why I asked .. And besides just cuz I don't get ain't mean it's not funny :)
Perry
Ah, well, can't say I know whether it's routinely asked for/looked at, but I started reading the rules for Solo and on one of the 378 pages of gobbledy-**** it said that all competitors must have a valid license. At the least, probably a liability thing.
rodmoe
LOL Ok it does get rather deep at time I mostly think thats to keep the KIDs out of trouble so if you look young (not like me) you may get cards and ya prob a liabilty thingy...
Perry
Look young, eh? I gotta put on my reading glasses to look at pictures of what young looks like these days.
Another thing to keep in mind, and this is kind of an unwritten rule of autocross, is that if you value the paint/windshield on the front of the car, when pulling up to the staging line always keep a good distance (1-2 car lengths) from the car that is about to go.. It is easily over looked because you get caught up in the heat of the moment, but since these are usually in parking lots and not on a prepped track there is all kinds of grit/dirt/rocks/ect. Be especially mindful if it is an awd or rwd car ahead of you and even more so if they are on some kind of r-compound racing tire, as all of that grit will get thrown up directly at your car!
Perry
As I understand it, the local chapter of SCCA will be having a novice clinic re: autocross hereabouts come April. I plan on participating, and the on following up with some local competition over the spring/summer, in what will be I believe straight stock mode. (Meaning I will be waiting until after this for any performance mods.) I am considering starting a thread describing my experiences getting going with autocross and any tips, hints, suggestions, etc. that accumulate as I go along. If you're new to the sport, or are considering it, you may want to follow along if I do that. Not because I'm an expert, but rather because I'm NOT an expert, but will be trying to learn from some who are. There are some very talented autocross drivers in the local KC area, as I understand things, and at least one will be driving a FiST this year, I believe.
Good luck, and Have fun! That is the most important part.. I went to a test and tune with mine this past weekend and walked away 10th out of 90 in PAX (basically an adjusted time based on class) with no prep besides tire pressures and a driver without much idea what I was doing... The other FiST there was on some better tires and ended up 4th in PAX, so the car definitely has potential!
Perry
Well done! I'm looking forward to giving it a go.
