The Official Fiesta ST Wheels Thread
CSM
If I were to go with the Sparco Pro Corsa 17x7.5s, what tire size could I go with to give me the most comfort? I may track my car only once a year so it’s an everyday car and don’t need a high performance tire.
You can try a 45 series sidewall on those but you may run into rub issues. Some folks report rubbing on OEM suspension on 215/45/17, some don't. Your mileage may vary depending on variations in tire size.
If your goal is comfort and you want to keep 17s then I would recommend looking into upgrading your shocks/struts. Seems that upgrading the rear shocks to Koni oranges (about $120) is starting to get popular for folks that don't track often. I've heard it eliminates a lot of the bounciness of the OEM suspension. I'm personally waiting for Bilsteins to get back into stock as I'm wanting to go with their PSS coilover setup
Actually I don’t have an ST, it’s a SFE 1.0. I plan on dropping it a bit but nothing extreme. Maybe do the Eibach pro kit.
I run stock size on my Corsa's. Comfort is really going to depend on the tire. My Firehawks aren't too bad. If you're really going for comfort, drop a size. I just got some 16" Sparco Terra's with Conti ExtremeContacts for winter and they are considerably more comfortable.
Throwback Wednesday!
16x7 +42 RAYS Volk Racing TE37 4x100 (11.2lbs)
205/40R16 Bridgestone RE-11
Redrilled hubs by Alex (no adapters)
ARP extended studs (M12 screw-in, makes for easy bolt pattern swaps)
Spacers (F 10mm, R 5mm)
Camber (F -3.0deg, R stock)
neeqness
I used the 205/45/17 with the Indy 500s and no rubbing when I was still running the stock wheel and that helped some. It will rub lowered though.
Another option is the Koni Orange shocks.
GTP
XXR 527 Chromium Black, 17x7.5 weighted in at 17.5lbs. 3CB456C2-681E-4CEA-A7DC-877FD9E041FC.jpg
KnockOff
I'm getting tires in about a month I'm trying to decide between these two. I dont drive the car much anymore and barley in the rain. Looking for cheap grip and I don't care about mileage. Any other recommendations will be researched.
Thx all.
FiSTerMr
Thx all.
For your needs, the falkens all the way!
FiSTerMr
I think our bolt pattern is only in 17”
A light 16" is the sweet spot I think for these cars. I was amazed how well these cars are with 15s and grippy tires (dunlop direzza).
I just got the dekagrams in 16x8, but have yet to put them on.
I kinda wish they were 16 x 7.5 , just so I can expand my tire selection to something not as wide as the BFGs I'm getting.
GTP
I kinda tend to agree with you on a purely performance standpoint. But even in 17” x7.5 mine weighted around 17.5lbs and I love how it fills up the wheel wells and makes the rally armor flaps justified!! ????????????
I’ll take the 1/200th reduction in performance. My next tire size though will be 215/40/17 on the 17x7.5. I think this will be a great ride quality vs performance enhancement!
FiSTerMr
I kinda tend to agree with you on a purely performance standpoint. But even in 17” x7.5 mine weighted around 17.5lbs and I love how it fills up the wheel wells and makes the rally armor flaps justified!! [emoji4][emoji109]
A big part of sizing down for me is rim/tire protection. I hit a quite mild pothole on the stock set up, and got a nice sized bubble on the sidewall.
17s make the tires look like rubber bands, imo. Not enough meat for my taste.
