Found and ordered some sequential / dynamic LED mirror turn signal blinkers
anyone check the fitment yet? Cross referencing their OE compatible doesn't match what I pulled up on tasca.
Aliexpress sequential:
Reference OE/OEM Number: 8A61-13B381-AF , 8A61-13B381-AE , 8A61-13B381-AD , 8A61-13B381-AC , 8A61-13B381-AB , 1542153 , 1531428 , 1513155 , 1748313 , 1547274
Taca: -B for the other side
Worst comes to worst, I'll look into retrofitting the sequential bits into the the OE lenses and then I'll take pictures and let you guys know how it works out.
Sent from my ONEPLUS A5000 using Tapatalk
danbfree
danbfree
Thread Starter #25
I was gonna say, these are very popular across the Facebook groups and every single person has said fitment is perfect and confirmed before I even ordered.
Mine came in the mail today! Box was a little beat up but the parts themselves were protected with a foam. Insert and are not damaged. I will let you guys know when they're installed.
jeff
That's great can't wait to see what happens. I got a box today, 2 lights, boy was I excited but then discovered upon opening that they were turn signals I'd ordered for my Prelude. :(
Please report once you discover if they fit!!!
If I can get to it tomorrow, I will. Weather is looking much better on Tuesday. So more likely to happen then. Will keep you guy in the loop.
I don't think the Prelude ones will fit. I guess with a little bondo and a hammer, maybe :)
jeff
Haha I worked a 10 today came home was tired but saw that box at the front door...10 minutes later they were installed.
Next, the Fiesta lights...
Those getting these lights PLEASE post the model year of your car and how well they fit. Because I have a 2019 and that is not listed on the compatability list. However I do suspect they will fit because Ford has carried many of the trim parts for several years without changing them at all. As soon as someone states that these will fit a 2019 I'll be on the net ASAP getting in an order for my FiST.
As far as I am aware, there are no differences in the wing mirror indicators between years. What we can do though, is since mine is a 2016, if it fits lets compare the model numbers of our stock indicator housing and we will see if they are the same and that should lay to rest whether they should fit your car as well or not.
I'll let you know as soon as I get these in!
jeff
#34
Here is a much better video that explains how the clips are situated, this will help prevent you from snapping/breaking anything, it's short and to the point and demonstrates mirror disassembly on a USDM Fiesta ST. Plus it features my Ukrainian soul brothers.
View: https://www.youtube.com/watch?v=t2q5iAN8rJA
#35
Alright guys!
We are installed! As we were hoping, these will drop right in and replace the stock indicator housing, getting rid of the chrome and giving you a sequential indicator! Very happy with it so far. I will report back after some time to let you guys know how these hold up. Hardest part of the install was trying to pop the clips on the wing mirror caps trying not to break them since it's pretty cold on Long Island as of late. If you guys want me to take any more pictures of them let me know and I will!
Video of the indicators running:
View: https://youtu.be/VpbyWB_2PyA
78855512_624618568406159_8376228989424893952_n.jpg 79345077_808632406254215_7956800208627564544_n.jpg
danbfree
danbfree
Thread Starter #36
Mine just arrived yesterday, I'm going to get them put in tonight! Good to see everyone having success with these!
#37
Excited to see it man. Hope you like it!
jeff
#38
Mine arrived today as well. I had a few minutes to look at it, removing the plastic retainer was easy but getting those three clips out not so much. I spent about 10 minutes but needed to quit so I will tackle it later. On my car anyway it’s not as simple as push the tabs and pop the trim piece out, they are quite tight.
The instructions show removing the mirror panel all together for more room but that is on the European model, does anyone know if it simply pops off on our USDM model as well? That would make it easier.
EDIT here are a few pictures:
https://public.fotki.com/greentrees2/icabod/1575410622393.html]
https://public.fotki.com/greentrees2/icabod/1575410638832.html]
[/URL]
https://public.fotki.com/greentrees2/icabod/1575410678617.html]
[/URL]
https://public.fotki.com/greentrees2/icabod/1575410718626.html]
[/URL][/URL]
#39
It does not appear to be possible to remove the the indicator without removing the cap. I also cannot find proof anywhere that the mirror glass is any different that the Euro part. But there are some videos online that show that you should just be able to pop off the lens. But to avoid that, If you aim the mirror down and in that should afford you enough space to pop these clips with a small screwdriver. What I did was pry each clip in a line one by one, and once I knew they were all pried a bit and just about ready to come out, I put a little bit of force into the outer most clip (pushing forward) with the screwdriver and it popped right off. Bear in mind after those 3 top clips come loose, there is also the little side clip and two little clips on the bottom seemingly used to locate the cap when reinstalling (Picture attached noting the locations on these clips).
