Turbo Technics S280
wetwea33
Still leaning out a lot up top.. Surprised that AFR isn't flat across the pull.
I'm hitting like 12.1 past 6k that really isn't lean but it's still not my final tune I'm sure it will get cleaned up once we add some more boost.
JDG
Just surprised to see it trending that way on aux fuel. From working with different tuners, my experience was always they start rich on the aux fuel and then rely on the STFT of the OEM ECU to take out extra fuel to hit an 11.5-11.7 target.
wetwea33
I get that but we added in some boost up top for this revision and it's a working progress and the weather has really varied here recently and the da is all over the place.
wetwea33
Yes but I remove that data from my logs for vdyno
Se7eN
I've always found that even if deleted it still makes for a wonky graph. Still really good spool and tq
wetwea33
For doing logs it's good to get redline data. Once it's finished I'll try to stop right before it to get a clean graph.
felopr
If he really cared enough, he would invest the time to take a video for us and post it up here rather than trying to describe a noise over the internet in less than 10 words..
Well here is the video
View: https://youtu.be/-1JHfLA4ep0
around 7 or 8 seconds when i give it the beams is the sound i am hearing
intake: ramair crossover - silicone elbow - s200 airbox
exhaust: whoosh catted - stock exhaust
14psi gate
I have triple check for leaks, no leaks
Something tells me is the exhaust that is so restrictive, or idk, whatever
like to hear your opinions, thanks
wetwea33
14psi gate
That honestly doesn't sound super normal but it's definetly not the exhaust. Almost sounds like metal rubbing on metal.
gtx3076
14psi gate
Sounds like a your turbo is failing to sneak a fart.
Se7eN
14psi gate
ok, that does sound really weird
felopr
I know, don't know what to look for
I have run 1k miles since install, did an oil change, the oil looks spotless, super clean. No leaks, no white smokes, nothing rubbing, etc
only thing i could think of is to put back on the stock bov and see if the one i have on is leaking boost, sounds plausive. if it was the turbo bad, it would had granneded by now with 1k miles on it
Se7eN
yeah, alot like high speed grinding of the walls of the turbo. Taking out the intake tube and a few picks or vid while the car on to see if it has any shaft play
Se7eN
I if it was the turbo bad, it would had granneded by now with 1k miles on it
Probably not bad just rubbing somewhere. Or the turbo is resting on the block too much (not enough clearance) and what you hear is resonance. Could actually be a ton of things.
Hopefully not a failure....[emoji852]
felopr
Is cleared by a mile from the block, i make sure of it. My money is on the bov slight leaking. Tomorrow will post about it if the shaft went to heaven
wetwea33
Now that I listed to it with headphones it definetly sounds like a leak or seals rattling. Probably the seals in the bov or it not being tightened down. Sounds like air escaping out of something.
felopr
Yep, that is what i am thinking also. Can you post a video of yours to give me a comparison? Thanks
wetwea33
There is a video of an s280 with a 2j in the fiesta nation Facebook group I'm not able to and probably won't be able to tonight.
felopr
Yeah trying to find that is gonna be difficult, a link would rock though
