God i love Mn....keeping things extra cold! It was 17 in the garage but as soon as I pulled out...down it went!
SPhilli911
Changed the battery because the car wouldn't start or jump after sitting over a week in below freezing temps. I also may have, just maybe, left the trunk open (it was latched, but not closed fully) for the whole week so the interior dome lights were on the whole time too. Oops. Car needed a battery anyways.
SPhilli911
Maybe it was the latch recall!
I can't seem to find a whole lot of info on trunk latch issues for the Fiesta ST (in my quick search), but I don't know if it was a faulty latch. I was using a sheet to cover the inside of my car to move wheels/tires around and I think the sheet just got jammed in the trunk door.
Business6
Rotating snow tires and replaced the battery. This car goes through batteries at 3 years on the dot in a four season climate. Replaced the original battery (car is from Arizona) the first winter I had it and now on my third at 59k miles.
Sounds worse than it is since I only now have a long drive to work at 50 miles a day.
Got my Fenders rolled and pulled, readjusted the height on the front to make way for new tires.
Finally took the first steps and a bunch of things came in this week
AP3 (going with Dizzy E30)
Whoosh street RMM
Brisk 1 step colder plugs
Ram Drop-in for now (ST200 box next)
Purple RokBlokz flaps
LilPartyBox
Replaced Upper mounts with new OEM and powerflex street inserts. No noticeable NVH increase at all. Feels so much more solid tho. Even steers and changes direction better! But my mounts were pretty far gone so the engine was basically a pendulum lol
While I was in there, FINALLY installed the FSwerks aluminum shifter bracket bushings I purchased 3 years ago. These were the final piece to compliment the SS and interior shifter bushings. Rifle action shifts all day. Lovin it.
Put in new reverse LED lights in my Spec D tail lights. The others lasted about 3 years! Re-did the gaskets I fashioned also as they are a one time use.
Can you link the reverse lights? Need to replace mine in the spec d and not sure what to go with.
pixelzombie
Whoosh street RMM
and a nice little ST keychain from Ron ;) View attachment 38192
First time I've seen those wheels, who makes them?
View attachment 38154 Did the rear wiper delete after quick as usual shipping from Whoosh
Did you have a hard time removing the plastic panel in the hatch? My clips would not come off and I didn't want to start breaking the panel. It was even creasing the panel at some points due to how hard I was yanking on it. It's a shame because I wanted to install the whoosh wiper delete too, but now it's just sitting.
Yes! It took me an hour or so to try and carefully take the panel off without breaking any clips and still broke a couple haha. But once the panel was off it was super easy and quick to remove the motor and close everything back up
How many miles did you have on original mounts?
