Stock Fiesta ST Wheel Information:
Size: 17x7" - 47.5mm
Weight: 22.5 lbs
Fiesta ST Hub Centric Ring:
63.4mm Hub Centric Diameter
Standard Fiesta Wheel Offset:
15" - 42-45mm
16" - 42-45mm
17" - 42-45mm
17x7" - 47.5mm (Included)
18" - 42-45mm
Depending on the wheel, you can go with an offset from 35mm to 47mm. The OEM Fiesta ST wheel weight is 22.5 pounds.
Fiesta ST Tire Sizes:
205/40/R17 84W (Included)
P205/40-R17 Bridgestone RE050A summer-only tires
15" Tires
175/65/R15
195/55/R15
195/60/R15
205/55/R15 (Recommended)
215/50/R15
16" Tires
185/55/R16
195/45/R16
205/45/R16 (Recommended)
205/50/R16
215/45/R16
17" Tires
195/45/R17
205/40/R17 (Recommended. This is the stock tire size.)
205/45/R17
215/35/R17
215/40/R17
18" Tires
205/40/R18
215/35/R18 (Recommended)
215/40/R18
Fiesta ST Spare Wheel & Tire Size:
15"x6" - 45.7mm
Tire Size 185/60 R15
Speed rating H
Load rating 84
Usage All season
Fiesta ST Bolt/Lug Pattern:
4x108
Fiesta ST Tire Pressure Sensors TPMS:
Ford Part# DE8T-1A180-AA
Weight: 22.5 lbs
15" - 42-45mm
16" - 42-45mm
17" - 42-45mm
18" - 42-45mm
15" Tires
175/65/R15
195/55/R15
195/60/R15
215/50/R15
16" Tires
185/55/R16
195/45/R16
205/50/R16
215/45/R16
17" Tires
195/45/R17
205/45/R17
215/35/R17
215/40/R17
18" Tires
205/40/R18
215/40/R18
15"x6" - 45.7mm
Speed rating H
Load rating 84
Usage All season
4x108
