Admin1
Stock Fiesta ST Wheel Information:
Size: 17x7" - 47.5mm
Weight: 22.5 lbs
Fiesta ST Hub Centric Ring:
63.4mm Hub Centric Diameter
Standard Fiesta Wheel Offset:
15" - 42-45mm
16" - 42-45mm
17" - 42-45mm
17x7" - 47.5mm (Included)
18" - 42-45mm
Depending on the wheel, you can go with an offset from 35mm to 47mm. The OEM Fiesta ST wheel weight is 22.5 pounds.
Fiesta ST Tire Sizes:
205/40/R17 84W (Included)
P205/40-R17 Bridgestone RE050A summer-only tires
15" Tires
175/65/R15
195/55/R15
195/60/R15
205/55/R15 (Recommended)
215/50/R15
16" Tires
185/55/R16
195/45/R16
205/45/R16 (Recommended)
205/50/R16
215/45/R16
17" Tires
195/45/R17
205/40/R17 (Recommended. This is the stock tire size.)
205/45/R17
215/35/R17
215/40/R17
18" Tires
205/40/R18
215/35/R18 (Recommended)
215/40/R18
Fiesta ST Spare Wheel & Tire Size:
15"x6" - 45.7mm
Tire Size 185/60 R15
Speed rating H
Load rating 84
Usage All season
Fiesta ST Bolt/Lug Pattern:
4x108
Fiesta ST Tire Pressure Sensors TPMS:
Ford Part# DE8T-1A180-AA
You mention 15" here. Do you think I can equip my 2014 ST with 15" steel wheels?
lessard.dcj
Q. Could i run a wheel with less offset to widen the stance of the car a bit?
a 15 will fit, your pare tire is 15x60x185 at 47.5mm offset and rim is 6" wide
The Fiesta ST supplement document specifies this:
"Compatible Snow Tire and Wheel Packages
Tire size: 205/40 R17
Required wheel: Original equipment ST wheel or equivalent
Tire size: 195/45 R16
Required wheel: Owner supplied. See your Ford dealer for suitable wheels from the Fiesta lineup."
1st question: Does this mean that Ford is instructing us NOT to put 15" on the car (even if the spare tire is 15")?
I found awesome WRC wheel covers for winter steel wheel.
2nd question: My sales guy told me that I MUST put alloy wheels and CANNOT put steel wheels for the winter. Is this true?
lessard.dcj
1st i know what the sup. manual calls for i supplied it. :p
2nd i made a call to Ford Performance and he said any wheel that fits this mk7 model should fit the ST, unless he has no clue, but he was the first person to give me intel on my car. so i feel i need to trust him
lessard.dcj
Mathieu
I do believe that the spare wheel is a steely, and since its a full size tire (not a doughnut) if it fits, so shall others[rockon]
I checked with a local tire shop in my region for 15" rims for winter and they recommended that I put 185/60R15 tires. I asked them if I could fit my old car's winter tires, which were 195/60R15. They asked me to verify with my dealer because that difference could void my warranty. Anybody ever heard of this?
MKVIIST
Just a little heads up! The day any of you even think about "stancing" an ST... Sell it... Sell it straight away and leave it for those who want a fully functional ST. :)
LOL, for me it depends on how aggressive the stance is, I prefer the flush look over the extreme stretch and poke.
YIN
195/55/15 or 195/60/16 + Black Steel are good match for winter.
Kip2MyLou
Does anybody know the weight off the stock 17'' rims? I'm looking to get Spring/Summer wheels and want ones that are lighter but I don't know the weight of ours.
rooSTer
I've read that the Fiesta ST wheels weigh about 22 pounds each.
How can you search to buy a spare stock 17" mag wheel/rim? Does it have a specific name?
I want a true spare for the garage so when I get a flat I can switch it whilst the flat gets repaired or replaced. I don't want to be riding on a space saver for any longer than necessary. Experience has shown me it can take a few days to get the full sized wheel repaired / replaced.
