Poll - 2j Racing intake - do you get p04db? Separated by pre/post 2016
Do you have a stored P04DB code on a Fiesta ST with a 2J Racing intake?
  • 2015-earlier car, stored P04DB code
    Votes: 0 0.0%
  • Total voters
    13
Chrisp5
Ransomville, NY, USA
I have a 17 I haven't noticed a stored code but I do get the CEL illuminated with the p94db code. It does seem to be 2-3 wot. Also I've driven the car for a long time here without the accessport plugged in and got no light. Now I have plugged it back in and I'm fighting with this code again. Anyone have any ideas?
Medford Oregon
Yo I’m a little late lol but coming out of the crankcase hole did you use the oem tube and just run it into the 2jr provided tube ? I’m getting a code and if you didn’t then I’m just going to copy you. I’m guessing it might fix my issue I used the bigger grey and orange tube directly to the crankcase. Any help would be nice:/
I routed everything (MAF extender, vaccum and the valve cover hose) through the little valley between the intake manifold and the valve cover right under the injector wiring. All of it fits under the engine cover while still having the sensor in place. All I had to do was twist the hose with the sensor the other way. The larger hose goes under the coolant reservoir and goes straight to the intake. Third pic shoes the check valve placement. For anyone reading this in the future, if you forget the check valve (little thing with the white on it shown in the 2nd picture) you will have a high and irregular idle, ask me how I know lol.
Side note: I do have the 2014-2015 evap line that Ron @ Whoosh carries
Link for evap lines: https://whoosh-motorsports.myshopif...-to-convert-2016-fiesta-st-to-2014-2015-specs
View attachment 22262 View attachment 22263 View attachment 22264 [/QUOTE
Medford Oregon
If got the grey hose I highlighted, I got it running straight from the crankcase hole could that be why I am getting code ?
Erick_V
Texas
I used the OEM elbow, then it goes to the gray supplied hose, then to the intake I believe. I unfortunately took this intake off years ago, so I don’t recall exactly how it went
