SteveS
G2BZ-5827406-CE
Hey everyone. I am looking for the rear passenger side. Is this the correct color for the FiST? Thanks for the help. There are a lot of references but I am not sure if this is correct.
Charcoal is the color for the ST. Stone is the color for regular Fiestas.
How is it? What did you feel that made it better a meant to be?
I wasn’t hitting targeted boost numbers (still low due to tuning) until 4600 and it wasn’t stable. I knew it leaked a bit but didn’t realize how bad it was.
Installed the worfab manifold, which fixed the leak. I’m hitting targeted boost now 1200 rpms earlier.
Have any vdyno logs? Where are you hitting peak torque? I have same manifold and turbo and still don’t make peak torque until 5k
I’ve been tuning it by pulls on the street. No dyno. 5k peak torque sounds about right though for me
Cneu
I was pulling into work the other night and heard a very loud/felt a hard clunk from the front right tire. Turns out I destroyed my strut mount. Luckily Napa had it in stock for the oh so totally reasonable price of $80. Took about 45 minutes and we're good as new.
XanRules
haha feel free to reach out if anything like this happens again.
Thanks homie. Fortunately it was two miles from home so AAA got me and it was a cheap repair! I still need your Forscan assistance for that camera but I've been slacking on finishing wiring it up.
First time doing an oil change after installing the Fumoto oil drain valve. I should've installed it from the get go since I don't have to worry about the oil stream hitting the brace or having to align the drain pan just right.
Best thing I did too* This is the one I used....comes with a Cap and the hose that you put in and turn to open the valve.
Stahlbus Oil Drain Valve Plug M14x1.5x12mm Steel - Clean, Easy, NO Tool Oil Change - Includes Oil Drain Plug, Washer, Cap, Connector, Silicone Hose
https://a.co/d/gUDgidY
pixelzombie
I looked that up and found this bit of advice: N-Series valve (with nipple to accept hose) is not recommended for passenger cars with low clearance. Is that of any concern if I've lowered my FiST?
Sam4
remember how cousin eddie describes his dog to Clark Griswald? "You ever see a set on a dog like that Clark?"
Pre ordered the Whoosh tubular manifold about a month ago. Will be installing as soon as I get it. Anyone know if there is enough space to get that in there without removing the turbo or is it easier to install it already attached to the turbo ?
BadShot
Got my Dizzy E gauge installed, Jason’s directions are mint. Also got the Cobb intake and Mountune exhaust on yesterday but suck at taking pictures of things while I’m doing them. God I can’t wait for warm weather so I can detail this engine
