Ultimate guide for those considering Euro projector headlights - all the basics in one thread!
SVTBob
U.S. Air Force Veteran
Arizona
Oh, ordered H7’s for the low beams. Should I have ordered H11’s ? Apologize for the ignorant questions.
Rural
OK, so after getting my OEM projectors functioning, I decided to upgrade the bulbs. So I went to BulbFacts and, based on their reviews, ordered a set of DDM Sabre LED 75W Max series on sale for $167 down from $230. On the order form it asked if I wanted a decoder box. Since I had not seen anything about decoder boxes on the forum threads, I said “no”. When the bulbs arrived I found that the bulbs did not seem to fit the socket (need an adapter ?) and that there was a box in the wire connector wiring. Have no idea what this could be but I will return them. Can anyone recommend a good LED that is compatible with the OEM projector housings that is simply plug and play ?
Does the collar flange come off of those bulbs, the part that gets clasped into the housing? That is a common method of getting them to fit, you remove the collar, clasp it into place, and then reinsert the bulb into the collar flange. As for the extra depth of the fan and wire/ballast, I had to get deeper 80mm rubber covers to fit over mine. The wires will just depend on what's in your housing, it might require some cutting and splicing...
H7 is correct, but depending on the housing of your particular Euros, you might need an adapter like the ones OSRAM sold to make theirs fit. The H7s that Diode Dyanics sell look like they would fit a standard housing, but I can't say I've used them.
SVTBob
Arizona
Thanks for the advice. I returned the LED’s I had bought, so I can’t comment on whether they would have fit with new collars. But having discovered XanRule’s argument in favor of not using LED’s in housings designed for halogens, I’m going to try the bulbs he recommended from Daniel Stein. If those prove satisfactory, great (they’re pretty cheap in comparison to most of the highly rated LED’s, so not much risk). Otherwise, I’ll try the Osrams that XanRules runs but which he insists do not perform as well as the halogens Stein sells. I’ll report back on my experience.
California
I
Thanks for the advice. I returned the LED’s I had bought, so I can’t comment on whether they would have fit with new collars. But having discovered XanRule’s argument in favor of not using LED’s in housings designed for halogens, I’m going to try the bulbs he recommended from Daniel Stein. If those prove satisfactory, great (they’re pretty cheap in comparison to most of the highly rated LED’s, so not much risk). Otherwise, I’ll try the Osrams that XanRules runs but which he insists do not perform as well as the halogens Stein sells. I’ll report back on my experience.[/QUOTE
California
I purchased the Vosla bulbs based on this thread. There is a definite improvement over the halogen bulbs I replaced.
SVTBob
Arizona
I have not had the opportunity to drive much at night but agree with 16MagST that the Vosla bulbs perform well, way better than the halogens that were in my projectors and are a great bargain to boot. And they are easy plug and play.
ronmcdon
Beverly Hills
thought I'd post here instead of starting a new thread. trying my best to do research on this thread and the one from Xan
https://www.fiestastforum.com/threa...need-to-know-about-automotive-lighting.17409/
with headlights, really hope I ordered the right set. Got this from ebay / Cars245
https://www.ebay.com/itm/174859865411
fingers crossed 'right hand traffic' means US market compatible.
with bulbs, seems like the Daniel Stern H7's seems like the right bulb for lowbeams
https://www.danielsternlighting.com/products/products.html
with highbeams Xan seems to recommend GE/Tungsram Megalight +120
but I'm having trouble finding them for sale in the US. Any alternatives there?
Not sure if there are any other bulbs or hardware to consider. Thinking of everything else just using existing oem components.
Thanks in advance!
XanRules
Portland
Thanks in advance!
howdy! In case you haven't sorted this out yet, I think I got the Tungsram Megalights from Daniel Stern as well, but they pop up on eBay from time to time. Right hand traffic should mean "US Market Compatible," I have the Cars245 right-hand traffic ones and they are correct.
The only other components needed is - optionally - a harness or wires to run the DRLs from the fuse box, but there's a writeup here somewhere about how to do that.
ronmcdon
Beverly Hills
Hi thanks for all the feedback!
I ended up getting Daniel Stern’s H1 55w Tungstam Plus 120. I figure between the wiring and blinker bulbs, hopefully I should be set.
going to do my best to get them installed latee this month along with some other mods.
ronmcdon
Beverly Hills
Ah spoke too soon. According to Daniel Stern the Tunstam out of production and ordering the 55w Flosser-Vosla-Osram Plus+250: for $53ish/pair
XanRules
Portland
Good to hear it!
For anyone else still lurking this thread - my driver's side low beam keeps going out. The bulb isn't burning out, that pin just isn't staying seated, either an issue with the connector on the headlight itself or the "plug" running from the car. Wiggling the connector temporarily fixes it. The pin physically looks fine with plenty of wire seated in it, no corrosion or damage. Anyone run into this before? I'd really rather not have to pay someone to figure this out for me, but I am stumped.
Dialcaliper
San Francisco Bay Area
Good to hear it!
Not sure if this applies in your situation, but does the pin seat in the connector with a solid click and without much forcing? If not, I’ve had issues previously with pin terminal crimps being too wide in the wire insulation area for some connector housings, preventing the pin from seating all the way in. You can sometimes fix it by squeezing the crimp narrower before inserting in the housing
XanRules
Portland
It seems to. It's an OEM connector, I and it isn't one of the ones you need to switch out to get the Euro headlights working. I believe it does seat with a bit of a "click" as described. It seems to have magically fixed itself, but if I run into this again - which I'm sure I will - I'll check that. I may also switch out the plug itself, one of the retaining tabs is loose/broken - like the ones in this photo here - and that might be the issue.
Mesa, Arizona, USA
My father gave me his TYC euros (swapped me) as an early Christmas gift. I have two questions:
1. Anyone with TYC got two headlights that have different colors in the DRLs? My driver side is more of a cool white, and the passenger is more of a bright white.
2. Is there some way to horizontally adjust the projectors? I can manually adjust up/down, but I think my passenger side is directed too far inward.
1) Temporarily feed power and ground to each DRL directly to insure there isn't a problem with weak ground or weak supply connection. ** Otherwise return them for exchange and hope they don't play games and ship the same ones back.
2) All headlights should have adjusters on them. Euro model lights can have cornering headlights which can complicate things. There is a way to get the stepper motor to move but it's been too long and don't recall how I corrected mine.
View: https://youtu.be/JQ3jyu6VEv8
** (they're only 5 watt so shouldn't be but owners may mess with the harnesses and create issues there)
Mesa, Arizona, USA
Is it possible to move the pin to the low spot for the DRLs, rather than just doing the quick swap to the high one? I broke the black clip that holds the terminal in place in the “DRL High” spot on my passenger body harness, so I’d need to go buy a new connector to make it work “correct”.
Also, does anyone have any suggestions on the LED low beams to get good projection out? I have some Auxito ones in, but they might be lower lumen, they aren’t stronger than my DRLs on high…
