Windshield Side Trim
Spring, TX
Apart from the driver's seat outboard seat base side trim, the rubber trim on both sides of the windshield are the only things cosmetically that I've found lacking on the new-to-me FiST.
Does replacing these require removing the windshield? No leaks, luckily, just something I've noticed & will eventually bug me enough that I want to replace them.
Need to get the windows tinted & would likely do a windshield tint [clear UV reflective] at the same time. Windshield is in great shape, apart from 1 tiny rock chip on the lower passenger side, so would rather not go through the effort of needing the windshield pulled if I can help it.
SteveS
Osage Beach, MO, USA
No. The garnish on the sides of the windshields is easy to remove if you understand how it's attached. There's another plastic piece below it which has several slots in it. The rubber trim fits into that plastic piece via a piece of plastic it's bonded to with tabs in it. Remove by lifting the bottom flexible rubber curved part, then popping each tab straight up. The top one slides into its slot. Replace by slotting the top one, then working down to secure each tab, then the rubber part at the bottom.
View: https://www.youtube.com/watch?v=tFcBAkONnrA
JAMADOR
Spring, TX
Awesome, that's a relief
Hoping a few $ here & there and it'll fully show off as nice as it is for 90k miles.
GA
Just did mine. Removed the cowling and trimmed off the cracking rubber at the edge and replaced the two side pieces. Pretty easy job overall and looks much better.
I have a new cowl (mine is falling apart right where it touches the windshield) and both of those new vertical trim pieces sitting in the spare room, waiting.
I just have to find the time and more importantly place to get that job done.
JAMADOR
Spring, TX
Just looked at my cowl trim & the rubber is cracked a bit. Guess I'll plan on doing all 3. Again, luckily, no leaks
GA
The rubber on my cowl was cracked and gummy. I just trimmed it flush with the edge of the cowl and removed the cracked pieces with my fingers, a screwdriver and a utility knife. Maybe someday I'll get a new cowl, but now it looks much better with the rubber gone.
I also removed the rubber trim from the bottom of the windshield and reinstalled it with some weather stripping adhesive. Make sure to get the lip on the cowl inserted into the groove in the bottom windshield trim.
JAMADOR
Spring, TX
That's not a bad idea, some of the side trim has already flaked off prior to my ownership
Just gotta be careful when putting the new ones in and slide it in the hook up top First..Then press down on each Latch point on the the windshield going from the top down Ive found. Also the ones off Flee-bay are Sometimes Fomoco ones with the FORD emblem scratched off the part. [cheers]
