Houston, TX
Does cutting some of the plastic for the bezel to fit making putting the stock fog light bezels back in later impossible or difficult?
You have to cut out everything from behind. I believe the stock bezel will still fit but the retention tabs will be cut off making it easier to remove but it still locks in rather tight. I have a hell of a time removing the stock bezel
Houston, TX
The stock bezel will.not fit back after cutting. I actually had to cut out everything from behind including the retention tabs for the OEM bezel. Worth it imo. Also had to rivet one side as it wasn't sitting in straight. Honestly a bit disappointed it didn't fit in as well as I hoped, but my whole car is kinda janky so idc
rallytaff
Los Angeles
Yesterday, got my wife's and my car's engine bays detailed. Both came up looking like new! The battery decided to quit yesterday in her car and I checked the receipt and it was one month shy of the end of the 3yr warranty. Died at the right time! So I got it replaced. Unfortunately, the warranty expires with the end of the old battery and the new one isn't warranted. If we can get another 3yrs out of this, we're happy!
Pics of per-say engine bays looking good or it never happened! [driving]
Houston, TX
Before installing my Mountune radiator I could barely remove the oil filter by squishing it past the oil lines. Didn't realize after installing the radiator it would be impossible to get the filter out 😶. What have y'all done with low clearance to get it out?
Grsemky
U.S. Navy Veteran
Arizona
You using a 400 filter? I used a lot of swear words and brake clean after
Ricky_Bobby_24
Active Duty U.S. Army
USA
