Went for a nice drive because the weather was comfy and got some induction and flutter sounds for a video. Love the TurboSX BOV, but I've not found any other springs they make and been wondering if I should swap over to something like a 50mm Raceport. Though I'd lose out on this wonderful audio.
https://youtube.com/shorts/D451miXoVpc?si=09cg838NOtHYSN8m
pixelzombie
drained my oil & tossed it right back in after driving 200 miles (used coffee filter to pull debris out), there was definitely glitter/shimmer all in that oil. pulled filter and cut the element out, almost no glitter in there. some black crud, carbon buildup getting out, whatever.
metal was not noticeable in the stream when draining but when i got to the bottom of the oil drain pan, it was. so, my motor will need to be rebuilt or replaced. i think i will start an “advice needed” thread or something. post the videos of each oil change i did there and go from there. i’m also getting excess pressure in my PCV catchcan which is making no sense atm. air getting forced out the dipstick hole when being taken out, maybe the intake manifold is plugged up. idk. torn on what to do with this car at this point. it’s silver and gold glimmer in the oil too i may add. this car has served me well for the 42k miles i have owned it and i don’t want to stop or switch to another fiesta, especially since this one is paid off.
what were the symptoms that prompted you to filter the oil?
XanRules
Pardon the clutter from other works in progress but I finally got this up and running. I think it may have been the single most tedious project I have ever done on a car.
This is an Enginetix Cybershift. Due to tariffs he no longer ships to the US and in fact I'm not even sure he's still around - I bought this at the end of 2024.
The install process involved completely removing the center console and shifter assembly (see Boomba's DIY video on how to install their shifter base bushings, which I did while I was in there). I bought a new aluminum lockout from Ron and a $6 aluminum lockout adapter on Amazon - I also had the Shift Solutions lockout, which I liked a lot better, but the threads are about 1/2" thick which lead to me not being able to get the shift knob on at a comfortable height. It also didn't like the lockout spring, it kept making a weird clicking noise when I tried to put it in reverse. This happened several times after installation and re-installation so I chalked it up to a design flaw. The $6 one played nice with everything so it won.
Okay so anyway, I had those two parts, installed them, mocked up a straight line down where the wiring harness was going to do, and used a friend's drill press to drill them out. I filed away a channel in the plastic reverse lockout mechanism under the shift boot for the wires to go through, cut away part of the collar that secures the shift boot to the lockout mechanism, and then snipped a tiiiiiiny hole in the top of the shift boot (redline goods) for clearance. I also snipped a little hole in the rubber washer that the lockout spring rests on. Once I had everything assembled and lined everything up on a work bench, I un-pinned one end of the connector and fished each individual 22awg wire through the holes/channel using a wire coat hanger and then re-pinned everything. I connected it all to make sure it still worked, then hot glued the connector in place because I never want to mess with this again.
I then drilled out the bottom of the center console (it is removable!) so I could run the USB cable into the little hub that's in there. I took this time to do the same with my phone cable, which I now have running up through the center console and coming out of the channel in the dashboard where the LED trim was on the pre-2016 cars (this is a much easier DIY I could write up). I tucked all the wires up nicely in the center console and reassembled everything. Before doing so, I learned that the new shift assembly was sitting slightly lower than the old one, preventing me from going into reverse as the lockout assembly wouldn't go high enough. I filed about 2mm of it off (as in Boomba's short shift lever instructions) and now it works fine.
This would have taken maybe two and a half hours total - including all the drilling and measuring - if I had not broken that god damn mother fucking piece of shit fucking flimsy plastic mother fucking shifter lockout mechanism that Ford made out of flimsy fucking plastic and does not fucking sell a replacement for. So this ended up taking two days while I waited for plastic weld to cure, then broke it again in another place, waited again for more plastic weld to cure, and then waited for a reinforcement of JB-Weld and two very small strips of steel to cure. If it ever breaks again I am going to shoot myself in the head.
Anyway, the reward for all of my hard work is: "heh heh heh big heavy shift knob lights up and looks cool."
Lost a fight with a parking lot today. Pulled into a lot and managed to scalp the Thermal exhaust brace / mount on the gate center post pocket that was made out of heavy channel iron embedded in the ground. Tore the front fasteners right out of the floor pan, pole vaulted my car into the air a bit. Totally destroyed the mounting points on the car and now my floor pan is “custom”…
Capri to ST
Finally got my vehicle registration certificate today in Italy. So in 5 days i'll be the proud owner of a Fiesta ST 1.6 😍😍😍😍.
Congratulations, you're going to love it. It's a whole lot of fun. The president of Ford said in a recent interview that it's one of the best cars they ever built.
If this were a public street, there was a chance that the city would pay for the repairs. Might be worth checking to see whether their property insurance might reimburse for a percentage of the total.
View attachment 69339 Got hit by a Dakota at a stop sign while turning left, it was my turn and he just decided not to stop and continue driving into my car without hitting the brakes. Thank god for dash cams. Insurance told me it might be a total loss, but the adjuster suggested a good shop with lower labor rates to be able to save it. We’ll see. They will be picking it up tomorrow.
Just an update, the insurance surprisingly didn’t total the car. I should be getting it back this week.
After two years in the boxes and agonizing over tire choices I finally got the Dekagrams installed on the car. 3074.jpg
I settled on Continental Extreme Contact DWS06 in 205/50R16 for tires. Gonna start at 35lbs in the front and 32lbs in the rear, see how it goes. Tail of the Dragon on Saturday and I'm stoked!
After two years in the boxes and agonizing over tire choices I finally got the Dekagrams installed on the car. View attachment 69457
Whoosh Thermal exhaust with the Cerakote tips?
Grsemky
Installed dizzy ethanol gauge. Painted it black for a more minimalist look
Where did you mount the sensor? I've been toying with creating my own but I'm not sure if I want to mount the sensor right off the tank or in the bay...
The dizzy kit mounts the sensor onto the ECU cover beside the battery. You then just disconnect the fuel line there from engine and into the sensor and run the supplied line into the engine. Two things to think about when deciding where to mount the sensor are the wiring and temp gauge. Engine side mounted means you'll need to run the sensor wire through the firewall while fuel pump mounted means running it through interior panels. Also the engine side mount would have a more accurate fuel temperature reading since it would be measuring it inside the engine bay where it gets the hottest
