My Car Dies
Okay FiST Nation, I have a 2015 Ford Fiesta ST with 94,000 miles and I am now experiencing issues.
The issue I am having is that my car dies when it's running. When it dies, the engine just keeps cranking but rarely ever turns over. When it turns over, it just dies again.
I have had the fuel pump replaced and it's still experiencing the same issues. I have had my reputable mechanic look at it as well as two very good ford master techs look at it and they hook up their computer with a special computer system and nothing shows up on their end. I took the tune off of it and shortly after, she started running again pretty well with a few hiccups but nothing terrible. After driving it a few hundred miles, I have decided to put the Cobb Stage 2 tune back on it and ran it for the rest of that day. When I got safely home with no hiccups, I parked it and went inside for an hour or so. I got back into my car and it started up fine. Backing it up down my driveway and it died again. I went to start it back up and it just kept cranking.
My question is: if it is the tune that is messing this up, how do I make sure that it won't happen again. What do I need to replace in order for it to be running 100%. Any help will be much appreciated. Thank you everyone and I love this car community!!
Hypergram
If it is the tune that is causing the issue (and nothing mechanical), I would suggest just flashing a different tune. The Cobb OTS tunes are known to be pretty garbage in comparison to a canned or pro tune from a reputable tuner, like stratified or dizzy. If it is something mechanical then if I had to make a guess it could be something to do with the spark, or possibly the injectors? Not really too sure though.
JDG
There are zero stored engine codes?
Woods247
Check your battery voltage after it sits overnight. When is the last time you replaced it?
kivnul
I am no mechanic. As there are 4 injectors I doubt they are a problem as all 4 wouldn't intermittently fail at once. I don't think this car has a fuel filter. Did you replace the High or Low pressure fuel pump? I would take a look at whichever one you did not replace. I would also flush the fuel lines if possible as you may have some sort of debris that plugs things up at just the right / wrong time. Once things settle, fuel can flow again. I do not know how to diagnose spark beyond pulling a plug when it wont start and check it against the block.
EDIT: As Woods mentioned, checking the wires to / from the battery & ground wire would be warranted as well.
Go back to the basics. A gasoline engine needs 3 things to run, Air, Fuel, and Spark.
Basic test for Air is to put a piece of paper against the exhaust outlet and see if it move while cranking. If no movement in the paper suspect a busted timing belt.
To test for Fuel that is dead simple. Crank the engine for a minute or two and smell the exhaust. No smell of gas means no Fuel.
Test for spark is also simple. Remove a plug, ground the threads, and crank the engine. Suggest wearing heavy gloves when doing this or you may get a jolt.
Once you determine that you do have Air, Fuel, and Spark what you have left is the computer/programming. If you are certain that the car runs perfectly on the OEM Tune the only thing left is the tune that is causing issues. I would suggest that you call whoever wrote your tune and talk to them. I would also suggest using your Accessport and write down any codes that are showing.
BenSanta
I have a feeling its the tune but I have no clue. I started it up yesterday and started up fine. I also took the tune off of it and drove it and no problems whatsoever. If it is something mechanical, I replaced the spark plugs, no changes. Thank you for the advice tho!! I'll keep an eye on those things and hopefully come to the solution.
BenSanta
On my access port, but not on my dashboard. It just says fuel pressure low and engine cranking. I had the fuel pump replaced and still throwing the code
BenSanta
I had the high pressure fuel pump replaced. I had my mechanic look at the low pressure and he said it was working great. The high pressure fuel pump NEEDED to be replaced. And the we flushed the fuel line.
JDG
The codes on your accessport originate from the ECU. Post up the codes here and we may be able to help. Just because your check engine light is not on doesn't mean there aren't any stored codes.
Clint Beastwood
havent had mine long enough to need to investigate, but does the fist have a replaceable fuel filter? if yours is gunked up or you have sediment in your tank it could intermittently block the filter and hold the gunk there, then when the vacuum dies down the particulate drops off and allows it to run fine again. This is a pain in the ass to troubleshoot, and the reason I always put clear in-line fuel filters on motorcycles I don't ride often.
kivnul
I believe the fuel filter is integrated with the pump in the tank. Supposed to last the life of the vehicle.
Maybe get a scantool and watch the crank sensor reference signal to see if it falls off and causes the vehicle to die. [thankyou]
Can you just reflash with the stock tune? drive the car for a couple days with the stock tune and see if the problem persists.
There was a thread that's well over a year old were someone was having a similar issue. Maybe worth searching for. I believe at the end the fix was the fuel pressure sensors. Don't remember which ones.
maestromaestro
I wouldn’t be too quick to blame it on the tune. For starters, I have been using Cobb OTS tunes for several years on my 2015 FiST (80k miles) and haven’t experienced any issues. Cobb, if anything, doesn’t make the tunes aggressive - for obvious reasons. Further, the tune would not be expected to act out intermittently - it is, after all, simply a bunch of 1s and 0s.
My money is on some kind of electrical or mechanical malfunction. Alternator? Check your spark plugs and cables. You may still have a bad pump, even though you had it replaced recently.
@maestromaestro - Agreed. Less aggressive typically (though not always) means less likely to result with running issues.
This was my thought as well.
https://www.fiestastforum.com/threa...d-stalling-in-idle-no-codes.17239/post-312133
Also, it would be unusual for an engine to stall and not have some code to pull prior to switching the ignition off.
