Turbo Technics S280
Se7eN
You can always download the datalog from datazap and plug it in. The road i log on isnt flat so it is not good for vdyno.
I barely ever read the forum when at home, so probably wont get to do it. But it's ok. Should still be good numbers.
KnockOff
With this turbo, is it going to net more power with 91 or e30? No aux fuel.
wetwea33
You would probably end up making more with 91 or around the same before running out of fuel.
KnockOff
If it was the same or really close, would the e30 mix be better to run for cooling and what not?
wetwea33
I'm not sure but I would suggest just getting aux if your getting this turbo.
MagnetiseST
The 595 rsrrs are pretty fantastic tires for the money. I would be going to the rs-pro next if these wheels didn't come with tires.
Same thats what I was looking at.
I think I got my final 93 revision last night, I havent logged yet, but it feels faster than the previous one even though there wasnt much left in the fuel system.
MagnetiseST
You'd probably make similar numbers. The E30 would allow you to run more timing, but you'd offset that with a lower amount of boost since the fuel wouldn't be there to support more timing and more boost.
KnockOff
If it was so similar might as well not mix. Idk about aux fuel. I think if I came across a used kit cheap I'd probably end up getting it.
wetwea33
I got my single port for 400$
gtx3076
I gotta stop watching this thread. I have my eye on this and the X5.
Anyone running the s280 on the gate that was provided with the turbo? I'm still waiting on the turbosmart one but I just want to start the tuning process already. Everyday I come home I'm staring at it on my table lol
According to adam at tune+ single port is all that's needed with this turbo. I bought the 4 port before I heard this lol
KnockOff
Just single part ey?
wetwea33
A single port is pretty good for pretty much every turbo for this car. Idk where this myth that a single port can only support this and that came from for a long time that's all we had.
Spork1569
So what advantage does a 4 port bring to the table? Cleaner valves or can it technically make more power as well?
