Thread Starter
#461
- Member ID
- #4208
- Messages
- 1,991
- Likes
- 459
Thread Starter
#461
Great, detailed write up [MENTION=6284]brbauer2[/MENTION].
I appreciate you telling me about the ECE projector pattern, I had a feeling that's what was happening. If you ever wanted to, you could always remove the projectors and shim the projector shield to get the DOT projector pattern but that seems counter productive and at that point, may as well do a projector retrofit to the factory headlights.
I'm glad everyone has been trying my customized D2S/H7 bulb and having good results.
Is anyone else having issues with the bulb clips? Mine are starting to get pretty mangled with the constant removing/re-installing of bulbs. I may try to find a more bulkier, permanent replacement for them.
[MENTION=3476]Roflwafflez[/MENTION] - the H11 harness will work as well, it's identically the same with the exception of the 9006 to H11 wire at the drivers side where you plug it in to the H7 headlight plug, but since your harness has the H11 connector, you can swap it out for the 9006 to H7 wiring that came with your 4-hole bulb boots.
