brbauer2
St. Charles
I need to get a set.
Did my first autocross since lowering with the Whiteline springs and have very minimal rub on the liner with my 205/45r17et40 setup.
Just a couple runs of the 20 [emoji44] we got have been uploaded.
Started with high 50s and finished with a 45.715 on run 20.
The entrance to the first garage was adjusted for the afternoon and that helped a ton.
My niece got to ride along for a few runs. My nephew was too little to ride but had a blast watching all the cars, especially the couple Corvettes. And my cousin's daughter is in from Reno and had a great time as well.
Pharr, TX, USA
I tried Cobb stage 3 on stock IC. Stage 3 is good but I need the upgraded FMIC☹️. I'll be getting it ASAP. I'm excited to try a better tune from either Dizzy or Stratified. How's stage 2 compared to stage 1. I haven't loaded it yet...
Central CT
I can now spin tires more easily and definitely feel a stronger pull from 3.5k to redline. I also think the car just runs overall better.
Portland
Today I finally got around to installing the ST200 airbox I bought from @OneDeath, thanks for that! Got it almost a week ago and finally put it in. I also logged some data on IDS out of pure curiosity, to see if the IAT changed much, but I failed miserably to create similar testing environment lol
Stock the IAT was almost exactly ambient, and ECT was 185ish.
By the time I got around to logging with the ST200 box the ECT was 213 and the IAT went up 20 degrees but ambient was only a few degrees cooler *than it was recorded at with the stock box*. I took some ugly pictures of the logger screen if anyone would actually want to see them, but my test was nonsense.
On another note, I think I hear a little more whoosh, but that's probably just hopes and dreams.
I might play around with where to route the intake hose, but it's already a pretty tight squeeze.
Sent from my LGLS990 using Tapatalk
brbauer2
St. Charles
Did some weight reduction and inspected the rubbing from autocross last week.
No damage to the tires, but some minimal rubbing on the liner/fender.
Whitelines with stock struts 205/45r17 et40 tire/wheel.
Have a buddy going to be parting out with some white 16x7 Sparco Terras with 205/45 Indy500 rubber. Probably going to jump on them.
Sent from my OnePlus 6T using Tapatalk
Phoenix
1st oil change using Pennzoil Platinum 5W-20 synthetic at 5K miles. Ran Motorcraft blend after dropping the stuff it left the factory with at 2K. Rear seat delete while I was at it.
Thanks! Its great stuff. The washes with Optimum No Rinse couldn't be easier, and Collinite 845 is one hell of an amazing wax. Great combo of durability and shine
The 845 stands up to A LOT of crap, and even makes the bugs easier to wash off of the front clip! [thumb]
