Turbo Technics S280
Se7eN
Well turbo install is finally done and on my base tune of 18psi its flowing more air then the stock turbo was on e30 and getting close to my hybrid on 93.
You'd be surprised how much better the airflow gets. I made the same WHP as stock turbo on just 13.8psi (spring pressure). I'm sure you're going to enjoy it a lot.
MagnetiseST
Update: Running out of fuel at 270whp hahaha. Time to look at 4port kits...
For reference though at 19psi its flowing 27lb/min of air. Working less hard than a VT330R to make the same power.
wetwea33
What type of boost are you hitting now?
Se7eN
That sounds about right for pump gas, get the Peron Kit from Whoosh.
JDG
That’s the plan.
I’m holding 22.5psi to redline.
Can you post up a log here? Would love to see the spool on a graph.
MagnetiseST
MagnetiseST
seems like a bit more % on the WG and could've reached 25psi at least
Oh I can hit 25psi. Its done it before (and it does it in 4th gear), its just not what I hold to redline without an upgraded WGA and aux lol.
wetwea33
The turbo should be good for at least 28psi on 93 with a solid wga and fuel for up top.
MagnetiseST
It definitely needs fuel up top. I haven't started to lean out yet, but we're just playing around with the fueling right now to see if theres more in the stock fuel system.
JDG
MagnetiseST
Wow, this is very impressive. Especially since ambient temps looked to be 90F. I threw something in vdyno just to visually see it. View attachment 24570
The car feels really great, i attribute the smoothness to my tuner, i love it. I'm seriously looking at aux come black friday, hoping strat or whoosh does a deal on their kits.
