Mechanical Changes/Improvements to FiST Through the Years?
koozy
It’s the top. Photos provide proof, And it makes no sense to make an aftermarket replacement that doesn’t replicate OE.
Sent from my iPhone
Well if it's the top it's a bleeder valve and I'm wrong.
koozy
these hooks are specific to the top, they are used to attach the ac condenser to the radiator. they do not exist on the bottom.
danbfree
You're right, the people doing the photos didn't even know up from down on that thing, the valve is on top, hehe...
Sorry to thread jack but I'm wondering if the mounts for the shocks/struts remained the same throughout production.
Will suspension designed for a '16 fit an 18 without modification?
thanks
danbfree
thanks
Yes, while there is a new part number for the shock/struts themselves as they got a little softer for '17+, you scan always cross reference off Tasca to make sure, but the overall design for the whole car remained the same.
Capri to ST
Capri to ST
Thread Starter #148
I looked this up on the Tasca Parts site, and you are correct, it does show a new part number for the shocks, actually starting from 2/16/16, which I assume references the build date.
https://www.tascaparts.com/auto-par...ont-suspension-cat/struts-and-components-scat
When buying aftermarket parts for the st many times 2014 through 2016 are listed or 2014 through 2017.
2018 and 2019 are either dropped inadvertantly or deliberately. Why is this
For one set of coilovers they listed every year up to 2019 but left out 2018. Don't know what's going on.
CarGuy
I know they changed the speedometer half-way through MY14 (different redline).
Can anyone clarify the change? Lowered redline or raised it? I'm curious.
Capri to ST
Capri to ST
Thread Starter #155
I'm just bumping my old thread to see if anyone knows of any new changes or improvements that were made through the years.
Based on your images, the 2014 shows a red-line point of 6,750 while the later revision shows ~6,500.
Personally never paid much attention to red-line. Like most (stock) vehicles it runs out of steam well before getting there anyway.
flbchbm
My printed 2019 manual matches the online manual: 8.5 qts rad. Here are some pics for the curious....it includes spring rate.
Wish it said super excellent paint job applied to last forever* FML
flbchbm
That's why I'm using Black Fire's Paint Sealant. Been using it since 2005. I'd like to get PPF on the nose, but, $1k+....
