Ya I would tend to say if one does not push the bigger or Hybrid turbo too hard than you can achieve longevity with our engines. They were built from the factory for turbocharging. Ya if you put aux fuel on and dial up crazy boost you will probably run the risk of blowing the engine.
On the other hand I have a great tune on mine for pump gas and E30 and the car has serious more power while retaining a drivability and not pushing it hard enough to go boom.
Its usually the people that try to push their boost to the highest extremes that get the boom factor. Even if I do go injectors and pump I am still not going to try to push above 30-31lbs and that would be at extremes. I am running right around 27lbs max now and the car is fast. On E30 I see a bit more HP and its got so much TQ its silly. If I did go further with fuel without a lot more boost I would be pushing 350hp and equal if not more TQ I already pushed 340ft lbs TQ on E30 alone.
So ya basically don’t go crazy with boost and being power hungry and the car will last.
If you are that afraid you will blow your car up? Then maybe you lack self control . J/K
 J/K
Keep it stock.
Keep it stock.
