So currently it looks like there are mostly 21-22mm bars available for our car. I am wanting something even stiffer. I am kicking around a couple of ideas. I have a tubing bender and can get nice chromoly tubing. I think I can bend some 1.00, 1.25, and should I go crazy 1.5in round tubing or bar.
I would think a 1.00in x .250 wall (would be about double the stiffness), 1.250 x .125 (almost triple) or .250 wall would be a good upgrade. The nice thing these are easy to change so testing would be quick and easy.
Need to figure out a holding fixture to test the Eibach bar I have and see what its actual rate is. Theoretically I can bolt it to the welding table, though not sure what the best way to fix a scale under it. It doesn't have normal poly bushings like a normal bar. Gonna need to think about this a bit.
