Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
I just did this on mine over the winter break and I can absolutely attest to the fact that it's life-changing. What a difference ! Thanks @KXNGABE85
I'll have more details on my build thread soon, but the gist of it is :
80mil butyl insulation as a first layer : LINK
394mil closed cell foam insulation as a second layer : LINK
Wow! The 3.5k-4.5k RPM resonance on downshifts is attenuated to a large degree and the cabin is much quieter.
how much weight do you think you picked up?
Montreal
The butyl panels were the most heavy parts of this. The thicker foam is quite light. I think I used five butyl panels overall. I'll weigh the panels next weekend and reply here.
Honestly, I think I added less than 10lbs.
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Long day and semi-long evening. When I got back from my son's bday party around 6 there was an EIBACH, Amazon, and Rock Auto package in the package bin. So installed the following after running into town to grab a spring compressor from Oriley's.
New wipers all around
Cobra Radar Detector installed and hard wired in.
H&R Springs removed and Eibach springs put in place.
Tomorrow, Discount Tire should have my new tires (KUMHO PS31s to replace Lockouts with RT660s), TPMS sensors and Dekagram wheels in for install. Then I have to swing by a few alignment places and see if they can squeeze me in. Tuesday it's back to regular work.
My suggestion for the Alignment is find The a garage the Local hot rod guys use that use string and measuring to get it done. i have found them to more precise and better than the machines do.
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
I used the string/jackstand method in the garage. Had to go about a half turn on each tie rod to get to slight toe in. Ive got a set of better metric machinist rulers coming in and some alignment tools as well so I can check my work done with strings and a tape measure.
I checked camber with my analog angle finder and Im between 1-1.5 degrees there.
Discount got delayed on getting my wheels in so I still dont have those yet. I'll be keeping the Lockouts and RT660s for more spirited use.
Cneu
Hillsboro, Oregon, USA
I recently did all my wipers just like Downsy. That time of year in the PNW.
I got under the car to take care of a mild boost leak. I tightened all the connections and clamps on the cold air side of the turbo. Not sure which it was, but hey the whistling is gone! I don't think there's a measurable difference in boost PSI. I still hangout around 24-26psi like before.
While under the fiesta I also tried to remove the rocks from the subframe. This is the most annoying thing about this car. I have absolutely no idea how these rocks get in the subframe and then I can't get them out. I drive gravel roads a lot so obviously that's how they get there, but i don't understand how they get into the subframe like they do. It sounds like someone is whacking my exhaust with a hammer when one gets into the right spot. Super annoying. All i can really do is give it a good rev to hopefully move the rock somewhere else. lol
My best alignments are always done by the latino/mexican tire shops here in my town. They do it by hand and it's usually faster than the chain tire shops. They're used to doing all kinds of weird alignments so they're more knowledgeable to work with, in my experience.
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Discount finally got my Dekagrams and PS31s in. The lockouts and RT660s are stacked in the corner of the garage waiting for non commuter duty.
1)i think I should have went Bronze
2)I wish the PS31 was offered in a wider size for this wheel or I should have went to a narrower wheel. The sidewall stretch is more than I was hoping for.
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Oh also forgot some smaller stuff.
New headlight assemblies to replace the fogged stock units. Got them from Carpart. Just stock type replacements. Ill polish up the stock units and put them in the spares shelf.
Proclip phone mount.
Replaced the weighted shift knob the PO out on with a leather wrapped round one with the ST logo and the shift pattern.
Ive got more random stuff coming in but thats it so far today.
I've had both color Dekagrams on my Magnetic at various times, and although the bronze looked a bit more 'classy' (and matched the metal flake in the paint somewhat), the satin black looks much more 'race/rally' and I like it better, especially with 205s stretched over them.
I think they look great on your Molten Orange ride. [thumb]
IF you did not need an all season where you are anyway, I would have gone with the Conti Extreme Contact Sport 02s in that 205/45-16 size (they don't even offer it in a 205/50-16, like they do for their DWS-06+).
But yeah, they are a bit more $$ than the very good PS31s.
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Thank you for the kind words :)
I'm an hour east of Dallas, Tx and work in an East Dallas suburb. I thought about going with something like the Contis or some RT615K+ since we do get a good bit of rain annually and winters get into the teens sometimes for short stints here but the majority of the time I'll just be commuting into and out of Dallas and getting kids on the weekends also in Dallas about an hour from my house. The higher tread wear rating on the PS31s along with still decent performance made more sense for most of my driving. And I've had them on cars in the past, both a Miata and MazdaSpeed3 and liked them on those cars even for some spirited mountain road trips. I'll be honest though, I've never driven on TW200 tires before and those RT660s are some confidence inspiring tires. We have a road south of my house with a series of 45-90 degree sweepers and man I never had to even slow down though those turns on the 660s. Just great turn in and grip.
I MAY take both sets back to Discount and have them swap the PS31s to the narrower Lockouts and the 215 RT660s to the Dekagrams. Even though the Lockouts are heavier (3-4 lbs) than the Dekagrams at least the performance tire will be on the lighter wheel. I'll give it a month or so and see if the "stretched" look grows on me.
Mesa, Arizona, USA
now you just need molten orange recaros, and it's done
or is it... s280 time?
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Nah. I'm really happy with the stock power. Look in the sig at my other vehicles. My next most powerful vehicle made 190hp new. Probably a lot less 30 years later lol. The Cj2 makes MAYBE 60-70. The YJ makes 130ish....or did 30 years ago lol. I've had more powerful vehicles in the past but the little FiST makes plenty of power for it's size :)
I wouldn't mind the Recaros, but even these base model seats are pretty comfy.
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Oh yeah forgot to talk about what I did yesterday :censored: Took the FiST out for a 90ish mile loop of local back roads, lots of 30mph sweepers and since most people were at work I had the roads to myself for the most part. Mostly did it to shake out the alignment, I did feel like it was pulling every so slightly left and the steering wheel wasn't perfectly centered, so when I got home I did another check and found the Driver's side wheel about 2mm toe out and the passenger side just about 0.5mm on the dot. I did a quick adjustment on the driver's side to 0.5mm toe in and took it to town to Sonic to get something to eat. Much better, no slight pull to the left and less torque steer.
Mesa, Arizona, USA
If you get a chance to sit in a set of Recaros (make sure it's the drivers seat, it's not as tight as the passenger), it might convince you to find a set.
SteveS
Osage Beach, MO, USA
This guy might want to swap seats with you: https://www.fiestastforum.com/threads/easy-seat-swap-from-recaro.33127/unread
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Today, Put Silverstars in the new headlight assemblies and new hatch struts. The old FOMOCO ones worked, but were very weak. I had to assist the hatch to full up and they would stay. New ones lift the hatch no problem. Then did the horrible trek into Dallas to pickup the kids and go back home, for a good ol 4 hour round trip to go 120 miles :(
KXNGABE85
U.S. Coast Guard Veteran
Florida
Hey @Volumetrik So glad to hear it worked out for you! You did a waaaayyy better job than me, great stuff!
