That should make them at least a little bit easier to clean, and keep clean. [thumb]
Is there any particular reason that you went with the 205/40 Neo Gens instead of the wider 215/40s?
Are you planning on slamming it, maybe?
Thas factory size, but i wish I had got 215s to fill the wheels up a little more. Next time. But now that i have looked it seems these 205s are the cheapest performance option. 215s jump to $160, these were $100.
I finished up my garage projects with some touch up paint on the hood and I put in the rear front subframe bushings. The fronts had weird bolts I don’t have sockets for so I’ll probably just have my shop put them in before an alignment. Also my Raptor battery is dead so I can’t get it out of the garage and put my Cadillac away.
My nine year old snow tires don't really have enough tread left to be useful in the Winter snows. (because tread depth is key) So... think about it... how would you treat them? 😈
Unfortunately I haven't yet taken the time to repair most of the damage from the hit and run so handling is tricky. But I can still make a fair bit of noise on take-offs! 😈
They show them out of stock until mid June, but TR has the 215s listed for the 'usual' ->(at most of the internet retailer prices) $125.00 each, currently.
I want to burn up (but not with a smoke show, just with regular use) my now 8 year old Altimax Arctic 12s as well, since they are 'aging out' rapidly, but they still have plenty of tread depth left. :(
Why they are still on the car now, and not my pure summer, 200 tread wear stickies (the recent cold spell, especially at night, has also influenced this as well).
akiraproject24
Front brakes done. Went Ford summer pads and EBC rotors, no drill or slot. New slide pin boots, pins were actually in excellent shape. Wiped em down and re-greased. Did about 6 30-10 and 6 50-15 hard braking and drove for about 20 minutes. Seems happy and the coating from the EBC rotors cleaned right off. Sucked out the brake fluid from the reservoir and put fresh stuff in. The pressure bleeder kit I bought didn't have an adapter that fit the Fiesta even though it explicitly stated it came with one. Returning that thing and just gonna have a shop bleed it all out with some Bosch fluid.
I store each individual tire/wheel in a garbage bag. My spare, I'll coat the sidewalls with silicon spray before bagging them. Minimize air and ultra-violet/heat exposure, minimizes oxidation. They've aged extremely well! Shouldn't be rolling snow tires 90+ but keeping the hand out the cookie jar so-to-speak. I tone it down on hot pavement for sure.
Is the (actual lug nut part) 'base' steel and the cover aluminum alloy?
Yup, steel base nut, Super light aluminum barrel and cap, can put spikes on there too if the zombies ever rise, instead of the cap. Palm scale says they are lighter then the acorn ones
I took off.
You put the base part on using the key socket then screw on the barrel parts, so each nut is a lock. my universal key socket kit didn't have a match to them. Its a 8 spline.
XR650R
I confess I've radicalized a bit since installing it, but most people who use the symbol in modern times are like, "yeah well, two outta three." I haven't found a suitable replacement from a visual perspective - ie, another round decal of the same size that more accurately represents my beliefs - so it stays on.
The symbol is most closely related to anti-Nazi Social Democrats who opposed Hitler while he rose to power in Germany.
The 3 arrows oppose monarchism, fascism and communism.
This was almost a century ago. In modern terms, it means no dictators.
Dialcaliper
The Tire Rack fairy dropped something at my doorstep today. They weren’t offered in this size until this year, so I’m really excited to try them out. 0125 production code…Hope they don’t rub…
XanRules
I'm aware of the history and the modern meaning, and that's what I keep it for. I just happen to like the third thing on that list - at least on paper - a lot more than I like the other two. ;)
What are these?
Dialcaliper
Yokohama Advan A052 or nankang sportnex cr-s. Pretty sure it's the sportnex
Your second guess is the winner! The A052 and a couple Toyos have been around in this size, but Nankang just released the CR-S V2 in new 16” sizes that were dropped in the initial release (the V1 was made in this size), but evidently they kept the molds, and now there’s a 225/45R16 in stock at Tire Rack!
https://www.tirerack.com/tires/tires.jsp?tireMake=Nankang&tireModel=Sportnex+CR-S&partnum=245WR6CRS
Excited to give these a good comparison with the set of 215 RE-71RS that are getting past the wear bars.
One tip is that you have to call if you want heat cycling on these, as it’s not a simple checkbox option at the moment as it is for some other tire models
Oil change and then I decided to start tracking down water leaks. Recently discovered water under the front seats under the carpet. Pulled the rear interior all apart and poured some water around the hatch. Sure enough definitely leaking from the taillight attachment points. One side was missing the tape over the hole too. Drove out to get some RTV, slathered it on and 20 minutes later a rain shower came through. :rolleyes: Next up getting the rear bumper cover off and checking all those spots. I'm pretty sure the plastic jawns for the top bumper screws are leaking. They looked awfully wiggly when i had the carpet pulled back. And maybe when it will be dry for more than a few hours pulling the seats and the carpet to let it dry out
