Irvine, CA
Boots & pistons going in the 986 calipers with DialCalipers brackets. Don’t have time to make the calipers look pretty.
Need to notch the ducting backing plate a bit.
New hubs/wheel bearings, inner/outer tie rods next on the list. Then onto the timing belt/wp…
SteveS
Osage Beach, MO, USA
Changed the oil Saturday afternoon and swapped the tires for winter. We've had 185/60-15 Yokohama Iceguard full snows since the car was new, but this year I decided to change it up with 195/55-15 All Weather Vredesteing Quatracs. We don't really get much winter here and so we spend most of the late fall through spring sliding away the tread from the full snows and not enjoying any meaningful grip in dry or wet conditions. So I thought the All Weather category of tire might suit better. Only about 170 miles on them so far, most of it a 160 mile round trip that was half on two lane roads. They ride smoother than the OEM size, a little noisier with a sort of low volume low frequency drone like a distant prop plane. Steering is far better than the pure snow tires and grip is too, though not as good as the summer tires, obviously. And they look suitably chunky. We shall see about the wet and snow performance when we get some of that kind of weather. IMG_20251115_171823_HDR.jpg IMG_20251115_171858_HDR.jpg
Those are 15x6.5 Motegis (or what width)??
For some reason Vredestein's tires always look to be a taller side wall (in appearance) than what the stated size says, as those look like at least /60 series side walls.
I am looking for some 195/55-15 pure winter tires, but none of the 'major/premium' tire brands offer them anymore (just some Hankooks and even lesser Taiwanese/Chinese/etc. brands).
It's gotten so bad with the huge 'donk' rubber banders as OEM sizes lately that Conti will not even offer their new(er), supposedly 'improved' over the 7s, Viking Contact 8 in ANY 15" sizes (at least through Tire Rack, maybe in Europe/UK they do [dunno]).
Even Nokian (Hakkapeliitta), which used to cover many many smaller sizes in their winter lineup offers less and less in the 15" sizes.
SteveS
The Motegis are 15x6 MR116s. I think the look of the tire might be that they don't run the tread blocks very far onto the sidewall.
Yes, although there's quite a number of tires available in 195/55-15, including 200TWs, there are no winter tires that size at Tire Rack. Discount Tire shows a Toyo winter tire. You used to be able to get Viking Contact 7 and Michelin Xice in that size, but no more.
Sadly, there are no Discount Tire stores anywhere even remotely close to where I am located, and ever since they bought out and merged with Tire Rack, I am at the mercy of whatever they stock for online sales from that whole company.
They tend to only stock larger sizes in most offerings, and skip many of the 'in between' smaller (15", 16") sizes we need to fit our platform, (even if the manufacturer actually makes those smaller sizes), and only offer what 'flies' off of their racks much quicker than they can replenish the depleted stock.
I will try Simple Tire and Giga Tire, as they seem to cater more to the smaller, less modern day rubber bander absolute trends, even in winter tires.
Houston, TX
Changed oil and filter. Since everyone says you can just pull it past the hoses I decided to just use my strength and do it 😂. It was tight but just had to squeeze it through. Putting the new one in was easier since I could tap it past the lines, instead of pulling. I don't think I could fit a bigger filter without a relocation kit
SteveS
Strength? You just have to thread it past them. It won't come out if oriented horizontally like it's installed. I unscrew it a little then let it drain. Then unscrew all the way and tip it down to drain fully. Once empty I turn it closed end down and work it past the hose. It has to angle a bit, then just pull down. Wear rubber gloves so you don't burn your hand.
Houston, TX
That's exactly what I did. But ever since I installed the Mountune radiator the clearance doesn't allow it to slip past with the engine side of the filter facing up. I had to face engine side up as usual and then pull really hard to slip it past the rubber hoses. When installing the new filter it got scratched from the metal hose clamp.
Grsemky
U.S. Navy Veteran
Arizona
What do you mean, there's plenty of space🥲🥲🥲
Is that an FL400S equivalent size filter?
When I use the Fram Ultra or Endurance PH3600s which are even a bit longer than the 400s, I can barely get them removed, or into place, even with the factory radiator.
Grsemky
U.S. Navy Veteran
Arizona
It's an actual FL400S, not the most enjoyable to remove but worth it for the extra capacity in the desert
@Grsemky - The damaged fins on the backside of the radiator is quite interesting? 🤔
@M-Sport fan - The FL400S was used on the 1.9L SOHC 88HP Ford Escort engine back in the early 1990s. They later downsized the FL400S. This was taken sometime between 2008 and 2010...
Caption: Left - Original, larger FL-400S Motorcraft oil filter. Right - New smaller FL-400S Oil Filter. Note, the 'designed and engineered by' clause has been removed. Part number remains identical.
