Atlanta
Yeah, it's gone, rip.
I had the same situation when I was looking for mine. All black and Grey. Was a long time before a white one showed up. I really wanted green, but those are super hard to come by.
You are OK, all that matters.
Spring, TX
It had an intermittent AFR CEL, needed a PS motor mount, and tires.
But man it was a blast of a car. Wouldn't mind one in orange either. Black and red are my 2 no-go colors.
Odds are I'll go a bit bigger, maybe a FoST.
Whatever it is, will likely go to my daughter, she'll be 15 in August.
Spring, TX
Stopped into the wrecker lot to make sure I didn't leave anything behind before ins takes it.
Surprisingly, all four windows were up (had all 4 down and the sunroof up), and all 4 doors still open/close [fronts with some resistance]
Damage seems to be pretty focused to the LF headlight area & radiated out from there.
Atlanta
It did its job, you are walking around fine.
Similar thing happened to my wife about 2 years ago, teenage girl hard to get across traffic RIGHT THEN - wife hit her straight on at about 45-ish - her car was over 2 feet to short afterwards. Was a sweet low mile Ford Perf Blue Edge ST with every option. Havent found another like it in decent shape. So she took my LR4...
Grsemky
U.S. Navy Veteran
Arizona
not "today", but the last 3 days.
put the old turbo back in. extracted two broken exhaust manifold studs. fixed my exhaust leak. cleaned the valves as best as i could. replaced the idler pulley since it was bad. found glitter in the bottom of all my oil i drained, so maybe the car is cooked. lots of miserable work, many cuts, many curse words. and i'm not even done with this car, which sucks too. i have to replace some broken/bad connectors, do some other maintenance items/big-ish items (namely cam bucket). i will post pictures once i have them from my mom's boyfriend's close friend whose shop my car was at all 3 days. i didn't snap pictures of the boroscope screen from dirty vs clean valves, but i will soon.
my midpipe does not line up with the downpipe very well or at all. i have a whoosh rmm, whoosh v1 catless dp, and whoosh poly exhaust hangers, but i have to put SO much tension/torque on the turbo and the downpipe to get this midpipe on it evenly, and it's a problem. i have no idea why that is. can the rmm let the car sag? do i need to replace motor mounts?
I've been curious about this! That sucks it's just one thing after another, I'm definitely curious about those pics and the glitter in the pan.
Grsemky
U.S. Navy Veteran
Arizona
Take their insurance for everything and get a FORS
Mesa, Arizona, USA
I would stay far away from modded FoRS... who knows what mods people have put on those & how the tunes have been... those 2.3 ecoboosts are not super tolerant of poor tuning or mod choices. Get a LOW MILE stock one and just drive it. They'll last.
Or, get another Fiesta.
Mesa, Arizona, USA
quite literally one thing after another on this car and it sucks. now my DRL is flickering on my passenger headlight (i broke a tab inside the headlight connector), and one of my coil connectors doesn't even click (broken tab). oh, and I still have an exhaust leak. i'm honestly at the point of considering moving to a different car. this needs too much. plus any and all maintenance items that haven't been done. several thousands of dollars i'm sure.
i think i will drain the oil again and see if there's more metal, or if it was a fluke. if it's still bad, it's going to be listed for sale very soon
Grsemky
U.S. Navy Veteran
Arizona
I finally found the broken wire leading to a hood ajar error, after months of dealing with it is nice not getting beeped at...
What I'm really looking forward to is the vibra mounts I just ordered from @ron@whoosh my passenger side has started clunking😩
Newport Beach
Bought a used access port. Installed this morning after my morning commute but haven't driven it yet. Have a drop in filter ordered and on the way. No other mods at the moment but I've been noting what gauges I need to monitor and their respective values for my current set up. Any tips from you more seasoned members are welcome.
Cheers!
Grsemky
U.S. Navy Veteran
Arizona
Cheers!
I personally monitor IAT, BOOST, WGDC, timing correction cyl1, AFR, and OAR...
If you're going to load a tune I highly recommend an intercooler, and the mandatory mod is definitely a RMM.
Grsemky
U.S. Navy Veteran
Arizona
RMM is next on the list then intercooler and pipes. What is WGDC? Do I really need to monitor timing I when I’m still otherwise stock?
Waste gate duty cycle, and yeah even in a stock tune it's good to track timing as negative corrections can be a sign of engine issues...
